Results 14 to 16 of 16
06-07-2008, 11:46 PM #14
Typically a 10 yr p/l warranty does not cover the thermostat. Sometimes it does. It just all depends on the contractor.
If you are truely dis-satisfied with the stat, you should call the contractor now and tell them you have used the stat and can't completely understand how to operate it. Tell them you have read through the instructions and it just seems to complicated for you.
If the contractor that did your work is a good, reputable contractor that stresses customer satisfaction, then swithing the stat will be no problem for them. The company I used to work for did it all the time. Mainly cause our salesman loved them Lennox Sig stats. No-one, including myself sometimes, could fully understand it. We changed a lot of them out.I fully support the military and the War on Terrorism.
06-08-2008, 02:06 PM #15
- Apr 2008
- Upstate New York
- 636
I dont hate it its just new and I dont do well with changes
I am sure they would chg it but I kinda like it if its not a total pc of junk I will keep it....
06-08-2008, 02:13 PM #16
Set the set back temps to where you like, and it will be fine.
