Results 1 to 8 of 8
    Jun 2008
    Replacement Lenox Relay
    Lenox model: b3-41-2-230
    The fan relay is sticking and Roth service tech says its obsoltete.
    Anyone know where I might order a replacement?
    Relay number: P-8-5892
    I have photos if it would help with ID.
    Regards,
    Bruce V
    503 841-2991
    Aurora, or
    Houston,Tx.
    Isn't that a time delay relay? I could be wrong I am not a Brother Dave Dude, I believe I could fix you up somehow if I were there.
    Frederick, MD
    A relay...
    is nothing more than an electrically controlled switch. I agree with MrBill. A good service tech can improvise, adapt, and overcome. Maybe you need to call one.
    As the others said, it should just be a delay relay. There are several generic delay relays that will probably work.
    You need a tech that knows how to do more then install OEM parts.
    Western NC
    so the partchanger couldn't figure it out, eh?
    I agree with the rest of the pros. Call another tech. A relay is a very simple piece of equipment. If he couldn't follow a schematic and install a different relay, then hes got some learning to do.
    I would have to have seen him with me today. Had to disassemble a shaded pole motor and reverse polarity. That was fun.
    Jul 2001
    I think the Lennox number 59512 replaces the P-8-5892. Your tech should be able to find one for you. Go to xxxxx The relay is pricey though.
    Since when do professionals tell what could be a DIY where to get parts over the net...unbelievable.
    in my lumpy chair
    if you keep replacing relays you will eventually find it or at least narrow the problem down
    I dont warranty Tinkeritus
    Jul 2001
    Whoops, got carried away with my respose. Ment to provide the number for the technician and just kept going with my responser.
