Results 1 to 13 of 35
Thread: new a/c not dehumidifying
06-07-2008, 06:22 PM #1
- Jun 2008
- 13
I just had a American Standard heat pump/ a/c installed thats blowing cool but humid air and cannot get humidity under 55 % in the house so its cold and clammy inside and even have some condensation on windows. Did installer undersize the unit?
06-07-2008, 06:23 PM #2
Call'm back. Make sure they have set the unit up properly...it can be adjusted to remove more humidity.
06-07-2008, 06:35 PM #3
- Jun 2008
- 13
Do they do that by lowering blower speed?
06-07-2008, 06:57 PM #4
If your fan is on "ON" try setting it on "Auto". I reduced my home's humidity today from 54% to 42% just by making that change.
White Bear Township, Minnesota
www.summitheating.com
06-07-2008, 07:14 PM #5
- Jun 2008
- 13
Thermostat fan setting is on auto all the time. Not much water coming out of the condesate drain
06-07-2008, 07:24 PM #6
- Mar 2008
- 6
I would guess fan speed isnt right
06-07-2008, 07:29 PM #7
- Jun 2008
- 13
Blower speed is very high, air has never come out of my vents so high, would lowering blower speed help remove more moisture?
06-07-2008, 07:36 PM #8
06-07-2008, 07:43 PM #9
- May 2008
- 21
we had the same problem whit our new Trane. The air coming out of the vent sounded like a storm outside so hard. The house cooled faster but not time to reduce humidity. Tech came and reduced speed to Medium. It is a variable speed air handler. It solved the problem. Or thermostat tries to reduce humidity by lowering temp by up to 3 degree below setting. This can make it cold sometime.
06-07-2008, 08:05 PM #10
Professional Member*
- May 2004
- south louisiana
- 2,199
lowering the speed will slow air movement across the coil allowing for better
dehumidification...
call them back.The cure of the part should not be attempted without the cure of the whole. ~Plato
06-07-2008, 08:09 PM #11
Call them back, and have them check system operation, not just slow the blower.
06-07-2008, 09:43 PM #12I fully support the military and the War on Terrorism.
06-07-2008, 09:59 PM #13
- Jun 2008
- 13
The owner just left and checked temps from return and supply and drop was only 17 deg. and also agreed it was humid. He's coming back this week to try and get temperature difference higher and lower blower speed and hopefully that helps. I'm really missing my 12 year old Rheem that kept the inside a nice comfy 35%-40% humidity plus you could set temp. higher with lower humidity
