Results 1 to 11 of 11
    Exclamation New Indirect Water Tank is Noisy! Anyone know why?
    Just had a new Weil Mclain Ultra 155 gas boiler installed as well as a Weil Mclain 60 Indirect hot water tank. When ever the water in the house or spinklers are being used, there is a rattle inside the tank. When we use the cold water only, it still makes noise.
    Anyone have any ideas? Im thinking this should not be and it may be a defect from the factory. Any info would be greatly appricated.
    Here is a pic...
    Jul 2000
    Northern Wisconsin
    Looks like whoever put your system in has a lot of pride in what they do and should be more than happy to come back and find out what's making the noise so that you're 100% happy.
    Western NC
    wow.....
    someone used the stickers......
    Could be a check valve making the noise.
    Have your installer come back and check.
    How many heating zones do you have.
    Well, the plumber that installed it does not know what it is.
    The supplier who he go it from says its normal. I called Weil Mclain but they are impossible to get a rep on the phone who will call you back....
    2 zones + the indirect
    You have to be a contractor or distributor to get a WM rep on the phone.
    Open up the cold faucet so it makes the noise, take a long screw driver. Plave its blade against the valves and other fittings, with your ear on the handle. When you get to the loudest fitting/device. That where the noise is coming from.
    low water pressure?
    Maybe the hot water is tring to force it's way back out the cold water feed line when
    you open a cold water valvem reducing the pressure. I'd get a flow check on the incomming cold water to the indirect.
    That would be easy to verify by touch before installing a valve that may not solve it.
    the noise is coming from inside the tank...not sure what else to do
    Close the valve on the cold water pipe going to teh tank and see if it still does it. If it doesn't, then you need a check valve like John said.
