Results 1 to 13 of 21
    May 2008
    liquid line temperature
    I just got my certification and I am still learning the trade. How hot can a liqiud line get on a hot day. If its 98 degrees outside.
    Houston,Tx.
    Pretty hot, I would say if it's coffee cup hot the charge is pretty close.
    Also depends on the indoor conditions.
    A high indoor load will increase it.
    Condition of outdoor coil, etc.
    May 2008
    inside temperature is 75 degree and outside temp. is 98 degree. the line temp. is 124 at the evaporator.
    Houston,Tx.
    Quote Originally Posted by sondown View Post
    That should be about a 300 psi liquid line pressure.
    May 2008
    Everything I have read anything over 275 head pressure is a problem. Is this true.
    Apr 2008
    Southern New Hampshire (USA)
    Depends on the system.... generally on the older systems, you were looking for a condensing temp about 30* higher than ambient... which at times will get you over 300. Newer high efficiency systems are different.
    Dirty condenser coils will do that too.
    N.E. Ok.
    Beer can cold and coffee cup hot, i knew there was something i could be doing with my free hand
    May 2008
    Thanks for all the information. I was afraid the temperature and head pressure was to hi. That the compressor was getting to hot and would lock up/ burn out.
    I cleaned the condenser with a condenser cleaner and water.
    The system is 15yrs old.
    Apr 2008
    Don't worry... if it does, you'll be the first one they call! (unless it's your system, then you'll still be the first to know!)
    May 2008
    Meridian, MS
    liquid line temp
    if a filter dryer is clogged would the line be hotter coming from the condenser and colder on the evap side and would it cause high head pressure? by the way, i changed my signature from tonydykes55 to apprentice because the more i read the less i realize i know
    td55
    Western NC
    Quote Originally Posted by captube View Post
    No, the proper terminology would be.....
    I knew there was something DIFFERENT I could be doing with my free hand
    Watering the flowers was very nice of you. But now its time to put away your hose and get back to work.
