Results 1 to 12 of 12
Thread: Register outlet temperature
06-07-2008, 12:09 PM #1
- Nov 2004
- 35
What is the general rule for an acceptable outlet temperature for A/C? I thought I remembered reading somewhere that 30 degrees below the outside temperature is acceptable. Any thoughts?
06-07-2008, 12:20 PM #2
how hot?? how cold??
20 degrees across the inside coil is more realistic. 30 degrees for a great AUTOMOTIVE AC..Often on older systems, 15 is all you get...
just measure the cold air return and at the registers and do the math.
Terrible installs or many variables, like long metal ducts suck up lots of heat. Ranch style homes with 60-80 feet of duct can hold a lot of heat...
Insulation is our best friend nowadays with energy costs going into outer space.
leaky ducts,not properly sized, uninsulated [helps in both heating and cooling seasons.]
06-07-2008, 12:28 PM #3
- Nov 2004
- 35
Thanks, so if it's 78 inside, the air coming out of the registers should be roughly 58?
06-07-2008, 12:45 PM #4
There is no one set temp difference.
06-07-2008, 12:49 PM #5
Professional Member*
- Mar 2006
- The South
- 1,847
bm
Just did a PM on my system back in May and took readings with digital temp gun at several supply registers in my home. time of day mid afternoon. outside temp was in the low 80s. Thermostat set at 75 degree. Gun was registering in high 50s.
IMO
06-07-2008, 01:04 PM #6
- Jun 2007
- Round Rock
- 2,890
The standard in the HVAC industry is 15-20 degree drop across the coil. Most will achieve 18 fairly easily. Lower than that and there is usually a problem. You can't really go by that if you have variable speed. It could be dehumidifying, in which case it is anybody's guess.
06-07-2008, 01:51 PM #7
- Jan 2007
- N.E. Ok.
- 1,296
Is that a I.R. temp gun?
They don't measure air temp., probably reading register temp or surrounding area which may be close to air temp.
If you want to measure the temp of a reflective surface or glass you can use a piece of black tape or paper mounted in contact with surface.
06-07-2008, 05:55 PM #8
- Feb 2007
- 106
so my system sounds like its doing ok. I placed a thermometer near my return air duct and then near my floor vents and got about 14-16 cooler air coming out of the vents, so it sounds like i'm not doing too bad, thats a relief to hear. I always thought 14-16 difference was really low, but my house is on a slab and the ducts are within the slab work as in the ducts consist of just areas within the concrete slab that are open, no metal ducts or anything, (which really really sucks) but i guess if i'm coming in very close to the lower end of normal than I won't worry about it.
06-07-2008, 06:09 PM #9
- Nov 2004
- SW FL
- 5,263
R.H. and Diffuser Temps are good comparative performance indicators
Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
06-07-2008, 07:32 PM #10
- Mar 2008
- 6
always heard 15 to 20 degrees as rule of thumb
06-07-2008, 08:07 PM #11
06-08-2008, 04:19 AM #12
- Nov 2004
- SW FL
- 5,263
R.H. versus coil dT ?
Designer Dan
