    Jun 2008
    Proper seer/system?
    My 13 year old Lennox coil needs to be replaced. The consensus sems to be don't replace just the coil but rather replace the entire system.
    The first question I have is what should should the minimum seer rating be on my new system.
    Secondly, is there a particular brand of system that is much better - or worse for that matter - than the rest? A couple of Bryant systems have already been recommended to me, one with a seer of 13 and the second one with a seer of 15. I live in southern Ontario, Canada so their is a need for air conditioning here for only about four months of the year.
    Thanks!
    Mar 2006
    The South
    dbbllb
    condenser and coil are both 13 yrs old?
    if electric rate is reasonable as I believe it is for your location, then a plain jane 13 SEER condenser with matching coil would be just fine.
    13 SEER is the minimum rated federal standard here in the states.
    IMO
    SW FL
    Hmm Think Heat Pump / Dual Fuel
    Use 13 SEER A/C ...
    15 SEER Heat Pump will save about $24 in cooling season for Southern Ontario.
    Designer Dan
    Unless you put a matched variable speed indoor unit in, you won't be getting 15 SEER from a "15 SEER" Bryant A/C. Dan's right, not much savings on high SEER up your way, here either.
