Results 1 to 7 of 7
    Jun 2008
    Trying to choose
    I live in central NJ and I am in the process of replacing my cental system witch after 20 years decided it was time to go. I have decided to replace with Lennox. I have a average size ranch house with baseboard hot water heat. All three of the contractors that have come out for estimates say 2 tons is good.
    My air handler of choice is the CBX32, but I am not sure witch condeser unit to go with XC14 or XC15. There is a significant price difference between the two and I wonder if I will ever see the payback with the higher SEER ratingof the XC15.
    Any thoughts from the gallery?
    Western NC
    The gallery's first thoughts are simple.......
    You get a Lennox, We'll get a good laugh.
    Get the most efficient system you can afford. Make sure it has the newer R-410A refrigerant in it.
    Next and most important is installation. If it aint installed right, your up **** creek without a paddle. Installation is key, system brand does not matter if its not installed right.
    The worst system is more efficient installed properly than the cadillac thats installed improperly.
    SW FL
    Hmm L O N G Payback obviously
    Quote Originally Posted by Railbirrd View Post
    ... average size ranch house with baseboard hot water heat.
    2 tons is good.
    My air handler of choice is the CBX32, but I am not sure witch condenser unit to go with XC14 or XC15.
    There is a significant price difference between the two and I wonder if I will ever see the payback with the higher SEER rating of the XC15.
    You might save upto ~ $30 per year with a 1 SEER increase.
    So the payback would likely be more than the equipment life.
    Designer Dan
    i install lennox and i prefer the xc15 its a little more quiet than the xc14, which is an issue if the condenser is located near a deck or bedroom window. make sure its r410a and go with the company that you feel most confident in. try to pick the guy who will do the job right. in the end its all in the install being done properly.
    hey...don't laugh at lennox
    Western NC
    Quote Originally Posted by badboyheel View Post
    Lennox aint just a laugh......
    ITS A BIG JOKE
    DC Metro Area (MD)
    What are the last 2 digits after the CBX32? The CBX32M isn't variable speed; the CBX32MV is. I'd get the variable-speed blower for efficiency and comfort. Go with the contractor who will size your equipment properly, check the ducts, etc...
    And 2 tons just happens to be what you already have.
    Hows your heating bill.
    What size, is an average size ranch house? 1000, 1200, 1500, 1800, or 2000 sq ft?
    Is your air handler in the attic or basement.
