Page 3 of 3 FirstFirst 123
Results 27 to 34 of 34
  1. #27
    Doubt it would hurt.
  2. #28
    Jun 2008
    been there,
    do you still feel the system is oversized or does it sounds like it's running normal now? And what run times should I expect after dark? Thanks
  3. #29
    Hard to say how much shorter they will be after the sun goes down and you don't have solar gain anymore.
    If after it dark its still 92 outside and your on times drop to less then say 8 minutes. Your probably over sized.
  4. #30
    Jun 2008
    beenthere,
    My run time is 8 minutes right now and it's 82 degrees out side my off time is at 20 minutes or a little more Humidity is at 52% right now inside. I know I keep saying Thanks but I really do appreciate your help.
  5. #31
    Atlanta, Ga
    97 here in Atlanta today...my upstairs unit has run for 12 hours non-stop to keep it at 75-76*...but dry...RH is low...I've been told that it means the unit is properly sized....Ruud 3 ton 13 seer.....
    Downstairs has run for 8 hours to keep temp @ 75*....Ruud 2 ton 13 seer...
    Very happy with the humidity levels...
    Joe
  6. #32
    Jun 2008
    That seems a little long to run without any stopping. But i'm not a pro at all. Thats why iv'e been asking all the questions on here so I know what to tell my installers.
  7. #33
    I had a couple 2 hour plus cycles yesterday on my unit.
    Today, I expect them to be longer yet, its suppose to get 2* hotter today.
    Monday, mine may end up running non stop in the afternoon, until the evening after the sun has gone down.
  8. #34
    Atlanta, Ga
    It's going to be hot up there in PA...mine cycles after the sun goes down as well....just a tremendous heat load on the house with bright sunshine and 97* temps outside....
    Joe
