Results 14 to 26 of 30
    Omaha, Nebraska
    return blocked. a-coil dirty. bad filter. bad blower. all would cause high head low suction. could be any number of things. get a real tech that actually investigates instead of changing parts.
    Jun 2008
    I just watch
    Quote Originally Posted by captube View Post
    Everone should have a imaginary tech as a friend
    He is a real tech. Maybe not so good of a friend. I have added freon to older units many years ago, but that is the extent of my hands on work on A/C units.
    Jun 2008
    Thanks for the lists of usual suspects. I know what a dirty coil looks like. I know what the blower thingy does too guys.
    Jun 2008
    Hiring competent help cheap
    [QUOTE=beenthere;1881935]
    Quote Originally Posted by classical View Post
    Sounds like your friend is a parts changer and not a technician. Is he the one that did the por quality weld?
    His assistant did a lot of the work. It seems like if a helper is any good, they start their own company.
    [QUOTE=JimJames;1882898]
    That happens when they don't get paid enough.
    Its also a poor excuse not to have good help.
    Bay Area, CA
    Aint that the truth, of course techs have imaginary techs as friends too. Well at least I do...
    wait is that normal?
    Jun 2008
    I will try a picture. I am new to this.
    This solder connection (read: weld) was done at installation 2 years ago. It joins the existing 3/4" vapor line to a 90 degree 7/8" elbow. Note elbow is crimped to form partial mechanical connection to vapor line.
    Jun 2008
    Quote Originally Posted by green jumper View Post
    These days my imaginary friends are all in PC games. All my enemies are there too.
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by spymoocow View Post
    you better pull out you refrigeration book!
    head pressure will not rise due to return blockage, a dirty Evap coil, dirty filter, or bad blower!
    your diagnostic opinions are not accurate!
    Quote Originally Posted by Airmechanical View Post
    head pressure will not rise due to return blockage, or a dirty Evap coil, dirty filter, or bad blower!
    A dirty condenser coil would raise the head pressure.
    Are you trying to stop the entertainment.
    Dec 2006
    Middle Tennessee
    appreciate it.
    Jul 2000
    NW IL.
    Jim James
    Please give us the following:
    Type Refrigerant: _______
    At the condenser:
    Suction Line Pressure _______ psig
    Suction Line Temperature ______ F
    Liquid Line Pressure _________ psig
    Liquid Line Temperature ________ F
    Condenser Air Entering Temperature _______ F
    Condenser Leaving Air Temperature ________ F
    At evaporator
    Return Air
    Dry Bulb Temperature _______ F
    Wet Bulb Temperature _______ F
    Supply Air
    At Furnace
    Return ________ inch WC
    Evaporator Inlet ______ inch WC
    Evaporator Outlet _______ inch WC
    Condensing Unit:
    Make: ___________________
    Model: __________________
    Evaporator:
    Line Set Size
    _____" Suction Line
    _____" Liquid Line
    _____ Length
    Aircraft Mechanical Accessories Technician. The Air Force changed the job title to Air Craft Environmental Systems Technician. But I've decided I'll always be a Mech Acc.
