Results 1 to 7 of 7
Thread: pressure check
06-06-2008, 02:47 AM #1
- Dec 2003
- 10
pressure check
i do home remodeling and have to check pressures on a typical ac unit tomorrow, (texas). it's a dumb question, BUT i do not want to lose refrigerant when i remove my gauges. the valves are not back seeted, so i just crack the low side valve after pressure check, and wait for high side to go to zero, then close low side and remove gauges, right? TY!
06-06-2008, 05:00 AM #2
Get yourself a set of low-loss hoses. If you can't afford them right now, they sell adapters to convert your standard hoses into them. That will solve your problem.
06-06-2008, 12:02 PM #3
If you got to ask this question. You don't know how to check an A/C. Call a contractor.
You are suppose to have an EPA cert to connect and disconnect hoses on A/C, and HP systems.
06-06-2008, 09:19 PM #4
first thing you do is contact the texas dept. of licensing and regulation in austin for the next available exam date,(hope you have 5 years exp. in the field). take the exam and pass, your'e on your way to the correct way not to lose refrigerant during a manifold removal!
"When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
"Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
06-06-2008, 09:42 PM #5I fully support the military and the War on Terrorism.
06-06-2008, 09:48 PM #6
06-06-2008, 09:51 PM #7
Well.......It was 98* today. Heat index 106*......ROOF heat index 143*.
I think I'll take a really tall glass of water. and free food and a re-fill before I leave for the next one.
Get to next one and repeat process.I fully support the military and the War on Terrorism.
