Results 27 to 33 of 33
Thread: Trane condenser leak
06-06-2008, 09:25 PM #27
- Mar 2005
- Houston, Texas
- 11,646
This is supposed to be a temporary repair . A flare will get them by .
06-06-2008, 09:56 PM #28I fully support the military and the War on Terrorism.
06-06-2008, 10:01 PM #29
- Mar 2005
- Houston, Texas
- 11,646
06-06-2008, 10:02 PM #30I fully support the military and the War on Terrorism.
06-08-2008, 09:03 AM #31
- Nov 2006
- N.Y.C.
- 27
Originally Posted by iraqveteran
I agree.
Problem is, the temp. repair stays in until it fails cause HO too cheap to fix it right.....
Then its our fault it failed again
that's why. you know what happens, when it's 97 degrees and the H.O. is sweating his **s off, we get blamed, especially if another company gets the call... most guys around here will blame the previous company. now the H.O. will be paying THEM for a job I should've done anyway. It's a no-win for us. so,i change out the unit- it's done right, and while the H.O. may not be happy in the short-term, he wont be pissed when his repair fails. i would rather be the guy who is know as "not the cheapest,but he does good work" than the guy who "charged me $xxx.00 and it failed again 2mos. later,so I called someone else. that unit was bad and he knew it". It depends on the customer of course.
06-08-2008, 09:15 AM #32
- Mar 2005
- Houston, Texas
- 11,646
06-08-2008, 01:26 PM #33
- Dec 2004
- 198
Where are you located? I have several older condensers that still work fine. If you live close enough and can show some proof that you are certified you can have one.
