Results 1 to 13 of 16
    Remote control thermostat by telephone
    I have a summer home that I would like to control the heat from the comfort of my Florida home in the winter. I currently have a four wire programable thermostat. The heat is propane gas the A/C is electric. The summer home is in Windham, NH
    May 2008
    Spfld, IL
    thermostats are starting to get real geeky! I talked this over with a buddy of mine. I'd love to see one that recorded usage (already there), temps and was able to be controlled by a text message from a cellphone. One that downloaded all the info to a laptop for analysis would be necessary to complete the geek fantasy.
    I'd be interested to see what others have found.
    Lancaster PA
    Honeywell make stats that can be control by phone.
    There are stats, that connect to the web, and record all temps, humidity, and graph it for you.
    Do a search on the net, many choicses available.
    Lancaster PA
    Steve.
    I thinnk Proliphix makes what you want, as far as web control and tracking, also text messages.
    May 2008
    Spfld, IL
    must r e s i s t temptation.......
    Dallas & Longview, TX
    One of the most geeky systems I've seen posted on this forum is http://welserver.com/WEL0043/
    Not sure of the texting interface though.
    Lancaster PA
    Quote Originally Posted by Daltex View Post
    That one doesn't do enough.
    Upstate SC
    If loving that system is wrong, then I don't want to be right.
    May 2008
    Spfld, IL
    HOLY KILOWATTS Batman!! That thing is LIVE!!! I've seen it before, but didn't realize it was instantous!
    is the delta T too high?? I'm seeing a 30.2 degree temperature drop in zone 1/2/3. I normally like to see 15-20?? I don't know where I got that # originally, but it seems to work pretty good.
    Upstate NY
    Do a search for a "cottage Sitter" I am using them in both the primary residence and vacation home.
    Jul 2000
    Northern Wisconsin
    Minnesota
    Trane and American Standard have a new furnace that you can control from your phone. It can also be programmed to call you and a few other people if there's a problem.
    http://www.americanstandardair.com/H.../Acculink.aspx
    White Bear Township, Minnesota
    www.summitheating.com
    Cedar Grove, Wi-Sheboygan
    Doesn't the Infinity control allow you to do this over the internet ??? I could of sowre I read somewhere either in the manual or on Carriers web site that the Infinity control can be controlled over the phone or ver the internet to adjust the temp and other setting as if you were right in fornt of the control, but you had to pay a small service fee per month for the service
