12.45 seer with expansion valve, 11.90 with piston.
Hi,
I have a builder installed system from 2003.
Lennox Merit Series
Outside Unit: 13ACC-048-230-01
Furnace: G40UH-48B-090-03
Coil : CH33-48B-2F
I wanted to find out what is the "max" or stated SEER rating of this system.
Also, was attempting to use the ARI site to find out the "actual" SEER rating, but could not find these model numbers.
Thoughts ?
Thanks.
Thanks. I belive this is a scroll compressor.
Was there a calculation involved or is this something I could have looked up somewhere ? Just curious.. for the future.
i am a Lennox dealer and got it from their dealer site.
I have a similar setup, if a Lennox dealer might be able to help me out as well:
I have a builder-installed system from late 2005.
Lennox Merit Series
Condensing Unit: 13ACC-042-230
Furnace: G40UH-48B-090-7
Evap. Coil : CH33-44/48B-2F
Guessing 13-13.5 SEER with the slightly smaller 3.5 ton condensing unit? Many thanks in advanced.
Anybody?
11.7 SEER with piston or expansion valve. 40,000 BTUs/Hr cooling.
Remember, Air Conditioning begins with AIR.
80% AFUE gas furnace, 88,000 BTUs/Hr input.
Kevin, much thanks... But I'm puzzled, why would my system be substantially less efficient than the OP's, although mine has a smaller nominal outdoor unit? Isn't a slightly oversized evap/blower or slightly undersized condensing unit the way most manufacturers get the better efficiencies from a single compressor/speed setup?
Sometimes. Actually most times. But it depends on the size & match up. Often the larger sizes do not do as well as the smaller sizes.
SEER rating are so embellished by EPA mandates and manufacturing testing. The only thing that truly matters is EER because it can be measured.
I will agree with that. SEER seems to have very little with energy savings. It is a rating invented by a committee.
EER is a much better indicator of performance.
Interesting. But EER was also a rating invented by a committee, no? If SEER is such a poor rating method, join/lobby the applicable AHRI committee and change it! AHRI is not operated by any one manufacturer, so I do not see how SEER would stick around if it were such a poor measuring stick.
Anyhow, is the EER rating available for my configuration? Thanks again!
I understand, was just pointing out both can be "smoke and mirrors" depending on who you ask. They both are maintained by the same governing entity, and both appease different manufacturers/bureaucrats/customers/installers at different times.
Either way, glad I've got what looks like a decent installation, using sufficient return air and filter sizing, with a decent efficiency considering it is "tract-home" basic equipment installed prior to the 13-SEER mandate.
Kevin,
I finally closed on this house last week!
Interesting, I noticed in the ARI charts for this condensing unit, I'm listed at 12.95 SEER and 11.15 EER for my cond/evap coil combo (this is for TXV, I'm reading 12.25/11.15). 11.7kW of cooling is listed... were you possibly reading from the wrong column, or do you have a different resource that shows ratings with my particular blower/furnace? Thx!
Nick
