Results 14 to 18 of 18
    34.8n 102.4w
    Hey Ryan... Had a c3-51 Lennox coil mated to a Bryant 036..... What do ya think that combo had going.....
    BTW... both were dirtier than .....at least my mind..
    DC Metro Area (MD)
    Who knows... was the air cold enough?
    Atlanta
    Cool Yes sir
    The model number gives you the tonnage. You will see a number such as 36 42, 48 ,54 etc.Somewhere in the model #. 36=3ton 42=3 1/2 ton so on.
    Whats my tonnage?
    I have an old Sears and Roebuck unit. Can you tell me what the tonnage of my system is? I want to replace my failing condenser outside.
    These numbers are from the evaporator in my attic:
    Model: 867.813150
    MFR. No.: 64755
    Type No.: 55-94753
    R22: 29oz
    So, there is a "50" in the model number. Does that make it 50,000 BTU for about a 4 Ton unit?
    BTW, the outside condenser/compressor eats about 25AMPs on one of the 110Volt legs . What can I expect a new unit to pull?
    Any recommendations on what to replace the condensor outside with (Brand)?
    Thanks a TON!
    You need to replace both indoor and outdoor unit.
    Can't tell you by that model number. But a load calc can tell you what size you need.
