Results 1 to 13 of 17
    Jun 2008
    Space in inches maximum that an outdoor unit should sit from an outside wall?
    How far from a home, minimum and maximum should an outside unit's base pad be? How far should that unit itself be from any wall?
    From other things, other units?
    I feel that my units are too from from my home. Looks strange from the street. Might be violating a HOA code, and kids could go back there and play. Too much room.
    My base pad is at 21 inches from (home) outside wall and my unit on the pad starts at about 23 inches from (home) outside wall.
    My neighbors pad starts at about 12 inches from his home. Looks much more professional. Not an eye sore.
    How much space do the XB13's need around them?
    Min?
    Max?
    Thx.
    Western NC
    How many more problems are you going to find????????
    Why is all this coming up now??????
    Trane systems I believe is 12 inches. I prefer at least 18. The more, the better.
    What else are you going to find wrong with your system?
    You get what you paid for. It too late to do anything about it now.
    Nov 2000
    Eastern PA
    For the most part, 12" is the standard minimum with 6-8" acceptable by most manufacturer's for one side to be from a corner wall if the other side is at least 12".
    Only for the purpose of not leaving room for people to get between the unit and the wall, taking a chance on damaging the unit, is there a maximum. There really is no maximum as far as manufacturer's or operation of the unit is concerned.
    If there are maximums from the HOA or local codes, then you should be asking them, not us.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by iraqveteran View Post
    How many more problems are you going to find?.
    i wonder if the unit color matches the house?
    Western NC
    Quote Originally Posted by Airmechanical View Post
    I doubt it. He's plannin on having it painted at the end of summer. Paint might fade.
    Jun 2008
    Only for the purpose of not leaving room for people to get between the unit and the wall, taking a chance on damaging the unit.
    Exactly.
    So 21" to 23" is leaving a bigger than needed empty gap.
    Looks awkward/sloppy instead of being tucked neatly into the side of the house.
    Kids will run back there, plenty of room.
    Sep 2003
    Portland.OR
    What are we doing??
    Trying to transfer the MAX heat to air possible at the condenser.
    Therefore as much room as possible, not under decks, low overhangs,
    tight against buildings. I've even seen fences built around them cause they are so cute!! And cut back the bushes.
    Cut the airflow and the heat from the house cant excape... so its not as efficient:..
    leland nc
    Quote Originally Posted by Clorox View Post
    Exactly.
    i try to keep all condensers i install at 24in off the house
    I will go 12 when there is a space restrition becuase of set back codes
    the more room the better for air and mainly for servicing
    try to clean or work on a unit that is close to the house.
    i find it amazing one of the most used things in a house is an eye sore and people try to restrict the hell out of it because they dont want it seen
    Always try for 24 inches.
    PITA to clean the coil if its only 12" from the wall.
    I think I just found out why my Clorox stock is down
    Apr 2008
    Consider getting the condenser outside of the drip line from the roof of the home. Ice from the roof can damage condensers.
    Bill
    Jun 2008
    NW Florida
    You know its always amazed me that a customer will wash and wax a 3000.00 car. But want t hide a 5000.00 a/c system. I would want to show it off. Just love holly bushes planted around condensing, Because some alarm company said it would prevent someone from looking in your window. Always found the action on a twelve gauge pump works best.
    Feb 2007
    out in the country
    I usually go around 24" out from the house makes servicing them easier. Tell the kids to stay away from your unit, its not something they should be playing around anyway.
    I never let schooling interfere with my education... Mark Twain
