Page 1 of 4 1234 LastLast
Results 1 to 13 of 44
    May 2008
    Spfld, IL
    recommend thermometer and Micron gauge
    I need to replace some worn out equipment. 2 out of 3 of my probes stopped working on my old Cooper black box. I'd like to try a different brand and style. Maybe some slightly bigger numbers and one with a backlight would also be nice. I was looking at the Yellow Jackets. Preferably one that comes in a box to protect it. Any online supply house recommendation would also be appreciated.
    thanks!
    Steve
    California
    i personally use these here, with no complaints.
    micron guage http://www.yellowjacket.com/AUTOProd...=29&c=102&p=55
    thermometer
    http://www.professionalequipment.com...qx/default.htm
    May 2008
    Spfld, IL
    it is hard to beat the quality of Fluke or the price
    Houston, TX, USA
    Thumbs up
    Quote Originally Posted by stevensondrive View Post
    thanks!
    Steve
    I use the new cooper electronic thermometer/humidity tester that comes in the blue box. It has a back light. I ordered the needle probe for it since it is fast response and fits in petes plugs easily. I use the yellow jacket vacuum gauge as mentioned above. Reads from atmosphere down to 1 micron.
    houston, texas
    Fluke 52 with the temp clamp is absolutely the best I have ever used.
    I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
    Veto Pro Pak - The best tool bag you'll ever own
    Va
    I use a cps micron gauge and it works pretty good.
    weber's Avatar
    weber is offline Professional Member/Membership Committee
    Southern Ca, Elkton Md
    Quote Originally Posted by Ricoch3T View Post
    Pretty good is not an option for a micron gauge.
    The gauge works better as a paper weight then it ever will as a micron gauge!
    I recommend you look at the YJ 69075 for a good micron gauge.
    As far as temp probes, it depends what you are doing with them as to what I would recommend.
    "Correct Installation is the Key"
    .1 has killed more HX then Rush Limbaugh
    What is your TESP?
    Quote Originally Posted by weber View Post
    ECHO!!!!
    Ohio
    ECHO!!!!
    I am currently using the CPS as well and love it. It works great and I have had it for about 2 months now with ZERO problems. Although....I like the YJ as well. Maybe that will be the next one I get....til then I am extremely happy with what I have.
    I need a new signature.....
    Oct 2006
    Emerald Coast, FL 30.1N 85.8W
    Fluke 52II & YJ 69080
    I use the Fluke 52II for everything -- by far the best field thermometer.
    I like the YJ 69080 because it measures in increments, is cheap, and does the job (lil bulky though). I also have a Supco LED that measures in increments.
    May 2008
    Orlando,FL
    The price is easy to beat. And the quality is really a matter of opinion. But i use this http://www.tequipment.net/ExtechEA10.asp and it costs less and works perfectly. Havent had a single problem with it. And im pretty sure it has all the features that youll need.
    Quote Originally Posted by Texas-Tech View Post
    My Fluke 52 has been collecting dust since I've been using the testo 905-T2.
    Anyone know how good this one is?
    14571 Super Vak-Check II
    It is highly rated by JimmySr
