Results 14 to 26 of 41
    May 2003
    Dixie
    Slatts...
    "During defrost the evap shouldn't pump down on a low temp system. The coil should have liquid in it to help transfer the heat from the heaters."
    Huh?...
    It is time for all good men to come to the aid of their country, for we are in deep crap.
    anywhere I want to
    Freezers in my part of the world, using that type defrost clock, pump down before they go into defrost.
    North Queensland, Australia
    The LLSV and the compressor should shut down at the same time at the start of the defrost cycle. The liquid in the evaporator helps to circulate the heat from the heaters around the evap.
    Read this page 9
    Mistakes are a part of being human. Appreciate your mistakes for what they are: precious life lessons that can only be learned the hard way. Unless it's a fatal mistake, which, at least, others can learn from. Al Franken, "Oh, the Things I Know", 2002
    anywhere I want to
    OK I read page nine and I still say freezers in this area of that make and using that defrost clock, pump down, shut off compressor on low pressure, and energize the heating elements. Since most don't pump down to 0 psi or less, then there is still some refrigerant in the evap that may assist in the defrost but , it still pumps down.
    I'm not saying your wrong, just how they work around here.
    I recently installed a unit with 2 solonoids......the one in the evap wired to the thermostat and the one in the condensing unit wired to the defrost clock. First time to see that type system.
    Quote Originally Posted by mdnbiker View Post
    I recently installed a unit with 2 solenoids......the one in the evap wired to the thermostat and the one in the condensing unit wired to the defrost clock. First time to see that type system.
    They may well be wired that way md.
    It doesn't mean they should be wired that way. The idea is to have a substantial amount of liquid in the evap to transfer the heat evenly through the coil.
    Get onto your local Heatcraft store or evaporator builders and ask what their engineers recommend. If you do it my way you'll find you have a faster, more efficient defrost.
    Dare to be different mate.
    Sep 2006
    Chicago
    Just thinking out loud here but wouldn’t a evap full of liquid have refrigerant migrate to the suction line during defrost if it wasn’t pumped out? I mean where I live it can be below zero for many days of the year. I would think certain liquid flood back on start up.
    appolgies if this has already been mentioned too tired to read all your posts.
    some boxes use 3 stats
    temp
    fans
    termination
    identify them its possible someone turned down the termination stat thinking it controlled temp and now your skipping defrosts because your terminating early.
    Quote Originally Posted by dangpgt97 View Post
    That would be a problem if you left the LLSV open. The Ideas is to shut down the compressor and the LLSV at the same time at the start of the defrost.That limits the amount of liquid in the evap. I have suction lines with old insulation coated with ice which would approximate the conditions you describe and have no problem with flood back unless the LLSV leaks. Also I think all low temp systems should have suction accumulators fitted.
    Sep 2003
    Turned out to be the defrost termination thermostat. Thanks for all your help.
    Southern Indiana
    Noted you're in PA. Do you work for a pretty large company doing supermarket work? If so; I know who can help knock sense into the service manager. What a bum.
    Ohio
    are you an in house guy or a contractor if your in house call a company that can fix it if your a contractor get somebody ummmmm your boss that can fix the damnnn thing
    anywhere I want to
    http://www.hvacrinfo.com/compressor_data.htm
    I must thank Powell for this link. As I tried to explain the defrost solonoid in this post, someone from where the water turns backwards suggested I was wrong and I should dare to be different. I was just on my way out the door to be different and change the defrost sequence in all the freezers in the southeast USA when I saw this link. Now I can go to bed instead and rest easily.
    I won't call Slatts by name but hope the person who said systems should not pump down in defrost cycle will read this..
    Gedday MD, I did
    Your turn. Page 41. Diagram 4 "Typical wiring diagram for single evaporator / single phase defrost etc"
    edit: through to diagram 11 on page 45.
    If you trace out the diagrams, (all 7 of them) You'll notice that the fans and supply to the T'stat and LLSV de-energise together on defrost. No pump down on electric defrost.
    And the waters turn...
