Results 1 to 13 of 19
    May 2008
    Grand Haven, MI
    Geothermal Open Loop Water Quality
    I recently discovered this forum and am learning a lot. Thanks to all who contribute here!
    I have a 15 year old house in western Michigan that I would live to convert to geothermal. Propane prices are horrible and the deliveries are a nuisance due to a long, hilly drive and lake effect snow. I have lots of land for a closed loop, and tons of water for an open loop.
    I would like to try an open loop system to keep my initial costs down. I could potentially convert it to a closed loop in a year or two if it proved problematic. The biggest obstacle I have is water quality. We have tannins in the water and a modest amount of iron.
    My question is whether there is something that could be done to improve my water quality. I recently met someone that was running their geothermal unit through their water softener. This sounded nuts to me, but it did cause me to wonder whether there is a compromise here. Assuming I only want to improve the water enough to avoid scaling (not necessarily drinking quality), is there a cost-effective way to do so? Is there another out-of-the-box approach that I might be missing?
    Nov 2007
    I would suggest installing a closed loop system from the outset – particularly if your water quality is questionable. Look for a design that will likely be the most trouble free from the start. This is an expensive project to revisit – especially when you’re freezing!
    Calculated over a 20-year life cycle, closed loop usually works out to be the most economical, all things considered.
    IMO
    SR
    May 2008
    Grand Haven, MI
    Thanks for the reply. I am not opposed to a closed loop system, but it's really not in the budget right now (perhaps a year or two). However, due to a failure, we need to replace at least part of our current system now so I thought it might be a good time to take the plunge. Has anyone made an effort to try and improve water quality for an open loop?
    wiggins
    The open loop with improved water quality would be very expensive and the quality may change at a lter date. The open loop is the best and it can be cheaper only if you have a manner of disposal, such as a pond. A closed loop can be less painful down the road. I have researched this and asked a lot of questions to make a determination. I still do not have geo thermal.
    May 2008
    Grand Haven, MI
    I can dump water very conveniently. We have a high water table and soil is all sand. Even if I dumped it behind the house in the woods, it would disappear almost immediately and go right back to the same aquafier.
    I see systems such as http://www.easywater.com/ which claim to eliminate scaling without using salt. I am skeptical, but the parent company at http://www.freije.com/ claims to be doing this commercially as well. If something like this could cause the water to pass through without scaling, then maybe open loop could work for me.
    PA/DE area
    I had a PUMP and DUMP in my home in a GEO,and I did it due to LOOP costs.I spent more money in well pumps and valves and my wife nagging,I swore I would never do for another customer!! DO NOT MAKE the same mistake.
    It's NOT the BRAND,it's the company that installs it!!!!!
    May 2008
    Grand Haven, MI
    I appreciate the warnings about open loop and water quality. Let me ask a different question. Is it possible to add a plate and frame heat exchanger to the setup to isolate the well water from the system? I know this is done commercially. Are there residential versions of these that might be cost effective and would do the job?
    Apr 2005
    NE PA
    Quote Originally Posted by marcusj View Post
    This is one solution, but remember you will have an additional pump and the associated power, small loss in efficiency due to thermal loss in the exchanger and you will still need to be concerned over water quality since it is in the primary side of the heat exchanger. Sediment and corrosives can be as big a factor in the heat exchanger as with the heat pump. Only advantage is that your costly heat pump will be isolated from potential costly repairs due to the water quality.
    paul
    May 2008
    Grand Haven, MI
    Tecman: thanks for the feedback. My hope was that a plate and frame heat exchanger would not only isolate the geothermal system, but also be substantially easier to clean. I just don't know if they make one that is practical for a residential setting.
    Jun 2008
    Open loop works fine for me
    I live in Dorr Michigan and my water is also on the hard side. I used open loop for years without problem, you do want to be sure your well pump can handle cycling more, you should definitely have a large well tank or tanks and install a sediment filter on the inlet to the furnace. True, you may have to run a descaling solution every few years as maintenance and you need to get a unit with cupro nickel. My water table is 4 feet and sandy soil, if I ever go closed loop I will look into a pond with a loop at the bottom. I'm not here to argue with the pros that install this stuff for a living, but I know from my experience an open loop system with careful considerations can be rewarding. Jim
    May 2008
    Grand Haven, MI
    manx82: I am in Grand Haven - I think about an hour away. We may be dealing with the same contractors. I set my contact info to be visible. Please email me if you would like to compare notes.
    Jun 2008
    In the Boondocks near Marion, IN
    Open Loop Worked for Us...
    We have a open loop Water Furnace Geothermal unit that is almost 20 years old. We have used the same well pump with 2 pressure tanks and have never had a well problem. We have only had to replace 1 compressor and do the general yearly maintenance that is recommended. I would not hesitate to go with an open loop system again. Our water quality was not perfect either. I would advice you to talk to different professionals who are reputable and listen closely to what they suggest.
    May 2008
    Grand Haven, MI
    Rickochet: Thanks. I have received quotes from three professionals. They all seem knowledgeable, but their recommendations on open loop vary widely. Anyway, I'm taking the water to be tested and I'm gonna go from there. It's nice to seem some people with good experiences.
