Results 1 to 13 of 13
    Jan 2001
    carrier economizer
    this is a smaller unit with just the standard economizer board. this building has 2 rooftiops. they are set up for differential enthalpy control set on d. the problem was they were calling for free cooling with 80 deg temps. i replaced the od air sensors to foolow up from another techs service call. i replaced them. with set on d mechanical cooling came on damper closed. switched to a and economizer came on mechanical cooling off. now today same thing no ac both calling for free cooling with 80 deg temps. everything wired right. control board is a hhg3aw001 od sensor hh57ac074 any ideas
    Dallas ,Texas
    Is it the honeywell board and where are you located ,like outside airtemp and humidity? Maybe a full model # too.
    When you say the standard econo board, most of us would think honeywell W7459. but the #'s you gave look like the Novar EconoMi$er+ package.did you verify 18 to 24VDC from contoller? and did you you measure the 4 to 20mA signal in the enthalphy circuit compared to ambiet conditions? before you replaced sensors. Do you have any more info? we want to help
    In my service van checking my lotto ticket
    Same thing...
    I heard another tech at the shop had almost the same thing going on with a couple of carriers but the units were calling for 100 OA damper position and the compressors were coming on! I would like to hear if anyone else has the same thing going on.
    He said he just ended up pulling the 24 volts from the OA controller. He also stated that he checked for the right connections and wiring of the differential ethalpy and all was OK on that end of it.
    things that make you go HHHHHHUUUUMMMMM....
    "If you can't explain it simply, you don't understand it well enough”
    Albert Einstein
    "Don't you just love when the flames burn off the wiring schematic?" hvacvegas-HTALK member
    On Monday, not even the chickens lay eggs...
    Hampton Roads, Virginia
    Quote Originally Posted by hvac17011 View Post
    If you are using differential enthalpy, you need to check the return air enthalpy sensor, if that is faulty then the control could be reading higher enthalpy in the return air than the outside air.
    Kevin
    "Profit is not the legitimate purpose of business. The legitimate purpose of business is to provide a product or service that people need and do it so well that it's profitable."
    James Rouse
    Jan 2001
    The model of the unit is a 48tme009601hq. the numbers in previous were carriers numbers. i tried removing return sensor which should make it just looking at outside air but it did the same thing. I have 2 units sitting side by side doing the same thing the one unit has 2 stages of cooling and the compressor was running. the manual says doing a checkout with several resistors and a 9v battery but i didnt have resistors.
    Anytown USA
    Quote Originally Posted by xarralu View Post
    a call from y2 will bring the mechanical cooling online even with free cooling available.
    Answers that question
    Huh, did not know that. Ill pass it on...
    Albert Einstein
    Quote Originally Posted by y7turbo View Post
    but shouldnt the oa damper shut to minimum at that point?
    Quote Originally Posted by brandewski View Post
    not with a 2 stage t-stat and the OA is ok for free cooling,the economizer is first stage and the compressor is second stage creating an integrated economizer.
    AIRFLOW IS CRITICAL
    Anytown USA
    if were talking about your normal honeywell 7459 , he dampers should modulate to keep a discharge temp of 50-55. or is it 55-60? i have to look in my book. too many damn things to remember! lol
    Differential enthalpy set up look at the total heat content of each airstream. If the oa was less than the return, it could do what you suggest. Are you using the right sensors? the carriers usually ship with a single sensor which is temp only, and for diff enthalpy you need to replace both. When you removed the return sensor, did you install the resistor across the terminals?? confusing the controller will only confuse you more.
    May 2008
    Jax Fl.
    According to EPIC, you have a digit off in your part number for the econo controller. I think it should be HH63AW001. The sensor number is correct.
