Page 4 of 6 FirstFirst 123456 LastLast
Results 40 to 52 of 66
  1. #40
    Fort Worth, TX
    Quote Originally Posted by CoquiLostInNY View Post
    beenthere, I have one return for the attic unit which is located in my second floor hallway. I have two returns for my basement unit. One of the returns is located on my main floor near the staircast to the basement and the other return (its really small) is located in the ceiling in the basement. I'll take those pics and upload them shortly.
    jrbenny, you hit in right on the button!!!
    redwing, I can't have my units balanced because the installer/designer didn't install dampers in my unit.
    Take some pics of those multiple supply register configurations while you're at it. While it sounds like you have other design/installation problems, the configuration you describe whereby you're supposed to switch between high and low (how...by closing dampers at the registers you don't want to use?) may be part of the problem (certainly not the sole reason), being either insufficient air volume supplied to the room, improper air distribution patterns, or both.
  2. #41
    May 2008
    Bergen County, NJ
    Angry
    Here are some pics of the supply register in my hallway as well as the multiple registers in my bedrooms.
    I also wanted to let you guys know that I turned on the unit responsible for my first floor (the unit not working) and noticed that instead of the outdoor unit throwing out hot air, it was throwing out cool/cold air. When I touched the pipes that connect the outdoor unit to the indoor coils I noticed that that pipes connected to the unit that was throwing out hot air wasn't as cold as the other pipe.
    Another thing that I noticed. When I opened the door to my first floor furnance/coil I noticed the diagnostic green LED was a solid color which as per the chart on the back of the door means the system is running without any issues. Guess the system doesn't know its broken... so much for a diagnostics.
  3. #42
    Ohio
    The diagnostic codes don't really do much other than let us pro's know where to start looking for the problem....just because a code says a part failed.....doesn't mean that part is bad...it probably failed for a reason. Trouble codes = Part changer's guide to idiocy
    I need a new signature.....
  4. #43
    May 2008
    Bergen County, NJ
    Its funny that you say that because I was on the phone with another HVAC tech and when I told him that the light was a solid green he told me that he wouldn't know where to start. Is it just mean or am I doomed to be without AC this summer.
    Question, does the cold air coming out of the outdoor condenser unit mean anything?
  5. #44
    Ohio
    It means your system isn't working right. Air conditioners do not "cool"....they remove heat...when you put your hand over the top of that thing it should be warm bordering on hot air depending on the conditions. (Thus removing heat) Cool air out the top is a sign of undercharge....for one thing....but in this situation I think you have other issues as well that we are all trying to help you with.
  6. #45
    May 2008
    Bergen County, NJ
    Once again, thank you all for all the useful info. Hopefully I'll get this issue resolved sometime in the near future and once I do I'll be sure to pass along the information on what it took to get it fixed.
    Wish me luck!
  7. #46
    leland nc
    in most furnaces the light is for heating mode and has little to nothing to do with ac mode
    i am a little curious about some thing here. Please just humor me on this as dumb as it may sound.
    turn on the dn unit and turn off the second floor unit. Now watch the copper lines and see if any of them start to ice up.
    i for some reason have a strange feeling the lines may be crossed and feeding the wrong unit or something along these lines.
    have seen this happen on ocasion not offten. I have had one once where the liquid lines were crossed and only found it this way.
    for new units seems to many problems and some one realy needs to spend some more time diagnosing and less time bs
  8. #47
    Ohio
    Quote Originally Posted by tinknocker service tech View Post
    That's a hell of a thought! (And we have all seen stranger things happen!)
  9. #48
    Id those high and low regs are hooked to different units. You got one of the stranges systems I've seen.
  10. #49
    Grundy Co. IL
    Speaking of strange things, we got called out to a church a couple years ago, because the installing company couldn't figure out why sometimes the units would freeze up, and other times they were fine. Somebody hooked up the 2-wire wrong, the only time it worked was on Sunday, when both units were calling for cooling.
  11. #50
    leland nc
    Quote Originally Posted by I_bend_metal View Post
    your right it is reaching but what he is discribing reaching is all that is left lol
    as far as high low registers i have done them many times and they do work i guess for the most part.
    dampers should be installed.
    the stat should be moved to master bed room
    2 ton for 750sq ft is a bit much and i also think the blower needs to be slowed down to about 70 percent or low speed as long as the unit doesnt ice up for longer run time and hopefuly better dehumidifing.
    jmo
  12. #51
    Apr 2008
    Alberta Canada
    Could be 4 supply lines
    Top 2 for cooling and bottom 2 for heating. they all have adjustable dampers and you can balance you system with out internal dampers use registers. You should also have more than 1 return air per floor. If yo have no returns in bedroom keep doors open. So heat can escape.
    Do it right the first time.
  13. #52
    Grundy Co. IL
    I've seen tnat done around here, but, it's with the high and low returns, not supply grills.
