Results 1 to 8 of 8
Thread: phasecut
    Jun 2007
    phasecut
    can anyone explain 0 - 20 phasecut to me. I don't know what phasecut means. I recently ran into some old staeffa actuators thar used this and would like to understand more about it.
    Aug 2005
    This is an uncommon control input signal.
    Phasecut: An actuator drives depending on the power result of a
    remaining wave. This signal type cuts the amplitude of the wave
    and the actuator recognizes this signal as a proportional movement.
    This control signal was used on the older Staefa proportional controllers. Some Belimo actuators can use this signal. OK
    Ohio
    Amplitude, meaning it chops off (goes horizontal) the peak of the sine wave.
    If you run into any older Staefa Smart cards, they'll have it.
    BTW, Atkinson Electronics sells a low cost 0-20V Phasecut to true 0-5 or 10 DCV board:http://www.atkinsonelectronics.com/p..._pdfs/ASM2.pdf
    jogas
    Jan 2002
    Fort Worth\Dallas, Texas
    Is that you James?
    Go Rangers!
    Ohio
    Quote Originally Posted by lwarren View Post
    Is that you James?
    Who are you asking? I'm not James.
    jogas
    Jan 2002
    Quote Originally Posted by jogas View Post
    jogas
    Yeah I was talking about jchapline, I think I might know him.
    Lane
    Go Rangers!
    Jan 2003
    This should give you a good idea of phasecut
    Jun 2007
    Yep, it's me. I ran into this on a job a felt like an idiot because I have never seen it. It seems like a well kept secret, from me at least, and then I started trying to run it down and could not find anyone else that even knew what I was talking about until I came to good ole HVAC-Talk.
    Thanks guys, I always know someone here will know the answer to anything.
    James
