Results 1 to 9 of 9
    Oct 2007
    Refrigerant lineset copper fittings
    Is there realy any difference between plumbing and refrigerant copper elbows,couplings etc?I know that plumbing tube is sized by its inside diameter and acr tube by its outside diameter and a 3/4 plumbing elbow will fit on 7/8 acr tube.
    Amount of restriction ells have.
    refer els are longer radius and thicker walled. water fittings are short radius causing more friction loss than refer fittings. water pipe is generaly sweated with 50/50 compound and refer line is brazed with a nitrogen shield at temps above 1500 deg. with 60/40 sil phos or 70/30 sil phos. refer brazing should be done bey a qualified technician only.
    Western NC
    Quote Originally Posted by referrob View Post
    ditto.
    type L long radius elbows are desired but short ones are used as well, you can braze or solder any copper you want but I probably wouldn't try brazing type N copper
    Western NC
    Quote Originally Posted by air2spare View Post
    I don't like the short ells. too much restriction. I use the short ones on drain lines. I prefer to bend copper if I can. Less brazing.
    Ohio
    Quote Originally Posted by iraqveteran View Post
    Absolutely....investing in a good bender can save alot of time and headaches on a job....I hate using fittings....I try to only have for joints...2 inside and 2 outside!
    I need a new signature.....
    I probably wouldn't try brazing type O copper either
    I want to watch you bend a truck load of type K copper
