Page 3 of 3 FirstFirst 123
Results 27 to 30 of 30
  1. #27
    Aug 2016
    Looking for A2 sensor part for ATI-80 gallon, has anyone found replacement part options? Help!
  2. #28
    Apr 2017
    capacitor replacements
    Hello, I am an owner of an ATI80 airtap, and sometimes is gets error code A5 and I think the fan for the heat pump fails to start. The company that installed it has replaced two capacitors but so far it does sometimes still blink that code and I have to turn it off and on again. I found this video on the issue
    apparently I can't post links but the users name is brotherboyd3rd
    tinyurl(dot)com/m8pno36
  3. #29
    Mar 2018
    ati66
    Quote Originally Posted by Latham View Post
    Just had to remove ati66 had it only for 6 years. For about 3 months the A5 code kept coming on. Did the same turned it off and on. Reading manual, its registers for increased pressure in the tank. Eventually the tank began to leak. Just replaced with stieble elton accelera 300 E. If anyone needs parts let me know before i take a trip to the scrap yard with it.
  4. #30
    Mar 2013
    Billington Heights, NY
    Just junk it. There's no reason to keep old parts for these POS things any more.
    This forum requires that you wait 20 seconds between posts. Please try again in 50 seconds.
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Pecmsg - "NEST should only be used with 3-M filters to guarantee total destruction of the equipment!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
