    May 2008
    electrostatic air filter
    Looking for a air filter that will stay in the opening better. Looked at the electrostatic filters as the metal frames will hold up better. So, are they a good product or cause problems with air flow
    Why not get an opening that holds the filter better?
    The electrostatic will cause airflow problems unless your ducts are sized properly.
    You may want to consider a high efficiency media filter.
    Rochester, MN
    Big tumbs down on that filter.. Get someone in to fit you a good media filter as last post said.
    Look into the AprilAire or Honeywell F200 or Airbear.
    Northen West By God Virginia
    Thumbs down
    Evert time someone around here buys one my cash regisiter goes ding ding!
    Apr 2008
    Alberta Canada
    Thumbs down They should be illegal
    Quote Originally Posted by pepster2 View Post
    They work for 3 months and you can't have humidity, but then break down and become too restrictive and start heating motor up until they quit. They will make your motor use more power.
    Do it right the first time.
    Louisiana
    Not Worth It
    I have used them in the past but they are a problem. Most have multiple layers and once dust and lint work there way in past the first layer it is imposible to wash out. Use 30 % Filters and maybe some foam tape to build a sealing surface in your grille.
    Mike
    The Impossible is possible around here.... It just cost a little more.
