Results 1 to 9 of 9
    Atlanta, Ga
    hissing TXV- continued
    No, I'm not a tech...if the hissing is normal, then so be it...system cools fine, but if hissing is not normal, then I need to call a tech to check it out....I have never noticed it before....please do not close threads so quickly....
    May 2008
    newnan,ga
    A undercharged system prevents the TEV from feeding properly and results in high superheat.The situation is signaled by a hissing sound at the valve,low suction pressure and low head pressure. Call hvac company to come look at it!
    Toledo, Ohio, United States
    Twilli says these mods are a mean bunch
    No Heat No Cool You need Action Fast
    If you would buy Twilli's latest book
    "Unawswered questions about Expansions Valves"
    you wouldn't have to get humiliated by that mean mod HeyBob
    May 2008
    Lehigh,FL
    Confused TXV making a hissing sound
    I have this question on a test I'm taking now and am having a hard time finding the answer??
    A technician hears a thermostatic valve (TXV) making a hissing sound while a refrigeration system is running. What condition in the system would cause this sound?
    A. Excessive head pressure C. Liquid line restriction
    B. Insufficient refrigerant charge D. Vapor line restriction
    Apr 2008
    Louisville, KY
    Or E: Call HVAC person
    round rock
    all of the above.
    Have it checked.
    May or may not be a problem that can be fixed easily.
    Howell, Michigan
    You need to call a service technician. Threads are closed on an as needed basis. Your original thread was giving too much technical information as this one may end up doing also.
    So, like everyone has said, have your system serviced by a professional.
    *******************THREAD CLOSED***************************
