Results 1 to 12 of 12
    Apr 2005
    Finksburg, MD
    Should I be concerned about this?
    I just had my AC coil and condensor replaced with a Heatpump coil and condensor. I kept the original furnace. I see that the new coil and condensor are 4 ton like the original set, but the new coil is not as wide as the old one. Is this going to restrict my airflow? I measure the temp at the filter box and then at the top of the coil and got 67 and 150 degrees. The sticker in my furnace specifies a heat rise range of 35 to 65. How bad is this?
    Inside Coil = 2TXCC049BC3HCAA
    Outside Unit = 2TWB3048A1000AA
    What was it before?
    Did you add a "better" filter?
    Take some pics of the ducts connecting to the furnace.
    Is there a duct coming out the side of the coil??
    Apr 2005
    Finksburg, MD
    What was it before?
    No changes to the filter. Here are two photos of the original unit and then some of the new unit duct connections.
    Washington
    Sounds like your gas furnace is running at the same time as your heat pump....big no no
    Apr 2005
    Finksburg, MD
    Quote Originally Posted by seatonheating View Post
    No. I'm sure it's not. The Installer used a Vision Pro 8000 stat and has the furnace tied to the Emergency heat wire. If I set it to heat mode the heatpump comes on, but to get the furnace to come on I have to set it for emergency heat.
    If they are both running,that's likely all that is wrong.
    If not the return drop looks a little small,and that size furnace(5 tons ,I think) should have a return on each sideor thru the bottom.
    Step back to take pics where we can see the ducts ,supply and return ,where they connect to the furnace ,plus more of the ducts.
    Dallas & Longview, TX
    You're still below the maximum design temp of the furnace. The new evap. coil is designed to flow around 1600 cfm of air so probably not the restriction if there is one. It could be the blower was re-wired wrong.
    My guess is that it was that high before when the return air was 67*. I'd wait for the pro's to respond as these are just my thoughts to ponder.
    DC Metro Area (MD)
    Is the heat pump outside running when the temperatures are that high?
    Apr 2005
    Finksburg, MD
    No, this is only when running the furnace. The heatpump temp is below 100.
    Rob
    Quote Originally Posted by robertc65 View Post
    Rob
    Then low air flow?
    How about some better pics of the ducts connecting to the furnace?
    Have him come back and wire it up the right way. Or are you going to throw it to emergency heat before you go to bed because it might get too cold for the HP to handle the load.
    I thnk you had a high temp rise before the new coil.
    As Dash said, post better pics of the duct work. And if youo can list their size that would help.
    Using a pen as a tape measure, assuming a 21" furnace, The return appears to be a 24 x 8, being generous at .1, it is only good for 1200 cfm.
    Not nearly enough.
