Results 1 to 8 of 8
Thread: bad run capacitors
05-19-2008, 09:37 PM #1
- May 2008
- 8
bad run capacitors
Airquest hac436aka 3ton cond. unit. fan & compressor not running. Found start relay bad, start cap. blown, & dual run cap open. Replaced all start components. Unit started up and ran. I left and went to next service call. Recieved a call back unit had quit again. Went back and found run cap. swollen and very hot. New run cap was bad. Replaced run cap. Unit has run 9 days and quits again. Fan motor still running, hermetic side of cap is bad. And start cap & relay also bad. Replaced all start components and unit is running again. What do you think the problem is ? Could compressor going bad ? It has not tripped breaker at any time. I don't think I could of gotten all bad caps. Any help would be appreciated. Thanks.
05-19-2008, 09:46 PM #2
- May 2008
- newnan,ga
- 57
did you check amps and voltage after each fix? was the readings normal?
05-19-2008, 09:51 PM #3
- Mar 2007
- media,pa
- 80
watch youre amp draws and did you ohm the windings
05-19-2008, 09:56 PM #4
Megg them both.
Check for any wires rubbed through, grounding intermittently.Sometimes when I consider what tremendous consequences come from little things, I am tempted to think there are no little things!
05-19-2008, 10:34 PM #5
- May 2008
- 8
I will go back in the a.m. and check these items. Thanks for the help.
05-20-2008, 06:30 AM #6
Banned
- Dec 2006
- Middle Tennessee
- 11,347
i would be checking the mfd's on them caps as well!
05-20-2008, 07:05 AM #7
Double check your wiring diagram as well, make sure everything is wired properly.
I need a new signature.....
05-20-2008, 04:18 PM #8
check amp draws every time you replace a capacitor and it will cut your callbacks dramatically. amp draws tell you alot about the wear on electric motors and even efficiency drops. i check amp draws the same time i check charge. those two things will tell you most of what you need to know about how a unit is performing.
