Results 14 to 26 of 51
Thread: trane xl16i vs lennox xp19????
05-19-2008, 04:33 PM #14
- May 2008
- 17
the labor warranty was only 1 year for the trane and 2 years for the lennox. !0 year for parts, etc. It was mentioned that the labor warranty can also be 10 years? Is that something the installer does separate from the manufacturer?
I read somewhere that the xl19i trane does not use the new freon substitute? Is this something to also consider? It is my understanding that the trane i was quoted and the lennox both use the freon alternative..,
05-19-2008, 04:39 PM #15
- May 2008
- 38
I don't really see it being very ethical to pad your quote to see if they will pay it and take some off if they won't but I don't know all the details. Both of these systems will have a 10 year parts warranty. As far as technical support it really depends on the local distributor, but Lennox has an 1-800 tech support number that you can always call, Trane does not.
05-19-2008, 04:43 PM #16
- May 2008
- 38
10 year labor warranties can be added for both manufacturers. Sometimes the contractor will include them in the price but at the least they should be able to give you an additional price to add the 10 year labor warranty.
That is correct about the XL19i, for some strange reason Trane still uses R-22 and has not shifted to R-410A in this line (although they will in the future). The XP19 and the XL16i both use R-410A.
05-19-2008, 04:50 PM #17
Banned
- Jan 2008
- Wisconsin
- 1,125
Everyone pads their price to make a profit. If you don't figure profit into your quote, you aint going to be in business long. My boss will simply give a quote, and if the customer says someone can beat it with similar equipment, he has room to drop it down a bit. He doesn't do it often, just if we really need the work. Do you have a problem with people comparing prices when furniture or appliance shopping? Or how about car buying..it's written in many car buying guides that it's ok to tell a dealer that another dealer will sell you a similar car for such a price. If car dealers, or anyone who sells goods to other people, can lower their price to match a competitors, why should this industry be any different? I probably wouldn't lower my price if I was giving the bids, i'd give one and leave it at that, but I see no problem with doing it. My boss isn't ripping anyone off with his initial bids. He gives the most detailed bids around here. But if he needs work for his guys, he'll drop the price down, and thus lower his profit margin. As for Lennox vs. Trane, I said ALL THINGS BEING EQUAL, including equipment, I would recommend Trane. Yes, the install is most important, it's just MY OPINION, based on units we service around here, that Trane is more reliable, and easier, and thus less expensive, to have serviced down the road. Nobody ever gives advice on here about what a unit may cost down the road to repair, and at least around here, Lennox's parts are a quite a bit more than Trane's. And I work for a Lennox dealer, so i'm not just blindly cheerleading for Trane because I sell and install them.
05-19-2008, 05:00 PM #18
- May 2008
- 17
Thanks to all for this interesting debate. What i will do is get a quote from the Trane guy on the 19i so i have apples to apples. It also seems i may need a 3rd quote and if i am lucky maybe it will be in between the other 2 and i can solve this dilemma that way.
I still have the question of should i care about r-22 vs 410A? In that respect it is not apples to apples.
This trane versus lennox debate seems to be a close one. Some pros and cons for each so in the end price (assuming 2 good installs) should be the decider, unless the freon is an issue to you guys.
05-19-2008, 05:05 PM #19
Padding your price and adding for profit are two different things. I have no problem with shopping for the best value at all. I do have a problem giving another company my price so they can beat it after I spent 2-3 hours doing the proposal correctly. I have run the manual J and they even get my sizing.
As far as reliabilty goes on Trane vs. Lennox maby the Lennox dealer in your area dosn't install the equipment as good as the Trane people?LOLIts a good Life!
05-19-2008, 05:07 PM #20
I would go 410A all the way. R-22 is going to just keep rising in price. Its already started and hasn't phased out yet.
Its a good Life!
05-19-2008, 05:09 PM #21
- May 2008
- 17
pricing
If it's any consolation, the first guy was here doing an annual maintenance. He did NOT do the J test and spent only about 10 minutes writing up his quote.
I have a third guy coming who said it will take 2 hrs. Given what you suggest it seems like he may be the most reputable of the bunch....
05-19-2008, 05:09 PM #22
Banned
- Jan 2008
- Wisconsin
- 1,125
05-19-2008, 05:13 PM #23
- May 2008
- 17
So the dilemma continues.......if you both recommend 410A and trane does not offer it in its 19 SEER unit, do i go for the 16 seer trane for let's say $600 less or the 19 Seer lennox since there is not 19SEER trane for an apples to apples comparison?
It appears to my naive view that for more money i get the 410A and more efficiencies, but $600 is alot of money......is it worth it!!!!!!??????
05-19-2008, 05:18 PM #24
r22
R 22 will be the same price as 410 for many years ! YES Im guessing just like everyone else . Id go with r22 just because its been a proven winner for 10 ka-zillion years . Im beting 410 wont be around when i retire .
My avatar is a picture of a Goodman Silencer .....These were commonly used in Goodman country ....Photos by hvac tech ( PaysonHVAC )
05-19-2008, 05:21 PM #25
Banned
- Jan 2008
- Wisconsin
- 1,125
05-19-2008, 05:35 PM #26
- May 2008
- 38
