Results 1 to 8 of 8
Thread: 14 to 13
    north western az.
    14 to 13
    can u install a 14 seer condensor with a 13 seer indoor coil? if not why? there couldn't be that much difference in the indoor coils could there?
    Jul 2002
    Zelienople, Pa
    It depends...
    Is it an ARI rated match? If so, yes. If not, no.
    SW FL
    Exclamation Match It
    Quote Originally Posted by glacierman2 View Post
    No one should recommend a combination that can not be verified as an ARI match.
    Why?
    It is not really supported by the manufacturer.
    Designer Dan
    It's Not Rocket Science, But It is SCIENCE with "Some Art".
    Lancaster PA
    Waste of money to do it. You won't get the efficiency your paying for from the condenser.
    Possible you could get less then 13SEER.
    Jun 2007
    Round Rock
    You can't really make a broad statement that it won't work. It depends on the manufacturer. You need to check the ARI. A lot of times the coils will be the same for a 13 or 14 SEER.
    Lancaster PA
    Actually, the ID coil doesn't have a SEER rating.
    Very good, been. I figured it would be Robo that pointed that out!
    Lancaster PA
    Haven't seen him posting much, so I thought I'd stand in for him on this one.
