Thread: small attic fan
    Question small attic fan
    Tamarack Technologies has discontinued their HV-700 insulated attic fan. I would rather call it a whole house fan, but it was so small that it could only really vent single rooms. Does anybody know of a similarly small (700 CFM or less), insulated attic fan?
    There are a couple of companies making similar products to the HV series, but I'd probably go for an HV1000 if you've been satisfied with the HV-700.
    I have an HV1600 and its okay. Pretty low airflow on low, but I wanted a low-and-slow fan to run all night when its cooler in the summer. The high mode does move air but wow is it loud. I really like the automatic opening insulated doors. Not as energy efficient as I thought it might be.
    If you're looking for smaller scale and less expensive, a low sones high flow or multispeed bathroom type fan with a piece of r-8 duct and an insulated wall cap can move similar amounts of air to the hv-700 with a similar noise profile and be placed inconspicuously.
    SW FL
    Reduce Run Time
    Quote Originally Posted by charles2 View Post
    ... but it was so small that it could only really vent single rooms.
    No, but you can run a
    http://www.wholehousefan.com/HV1000brochure0106.pdf
    2/3rds of the time of an HV-700.
    Designer Dan
