Results 1 to 8 of 8
Thread: Is this too much hardware?
05-14-2008, 09:09 PM #1
- Apr 2008
- Boston
- 43
My 1500 sf house, 2 floors, Good installer says:
Carrier 16 Seer 2 Spd HP
Variable Speed handler
change to 2 zones
Is it worth saving $1000 each to cut back to 14 Seer 1 speed HP
and/or stay with single zone?
05-14-2008, 09:42 PM #2
I thought you said it was 1700 sq ft.
Do you mean 2 16 SEER units.
Or 1-16 SEER unit zoned.
05-14-2008, 09:55 PM #3
- Apr 2008
- Boston
- 43
its 1650 less the closets and storage
1 16 Seer , 2 speed heat pump, zoned
05-14-2008, 10:37 PM #4
- Jan 2008
- 56
You have not given enough information. I owned an 800 sf home that ran through 1000 gallons of oil per season in 4500 degree days. You can't project energy savings without some notion of what your energy cost is over the useful lifespan of the gear. So you can't make informed choices without that data. If you save 10 % off of a $300 yearly expense, it's not the same as saving 10% from $3000 yearly cost. At $3000 yearly energy expense, better equipment will pay back even if you finance it so long as you live there for a while.
05-14-2008, 11:02 PM #5
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
05-15-2008, 06:13 AM #6
If your looking for comfort. I doubt you'll have a complaint going with the Infinity 2 stage and zoning.
05-15-2008, 10:43 AM #7
Professional Member*
- Mar 2006
- The South
- 1,853
msjoy
what size Carrier Infinity 16 HP?
has your dealer performed a Man J heat/cool load calculation?
what size are you replacing?
has ductwork been checked as to size, condition, supply/return?
05-15-2008, 11:46 AM #8
- Apr 2008
- Boston
- 43
I am replacing 3 ton with 3 ton and certainly the infinity 16 will do a great job.
A york 15 Seer will give me better heat at a lower install cost here in Boston area.
I calculate the saving to be about $100/year for each SEER number so payback is a while after the jump from 10 to 14 or 15.
This is like buying a car without being able to drive it
Thanks to all of of you
