Results 14 to 26 of 37
05-25-2008, 09:04 PM #14
- Jan 2005
- Veterans Home Yaphank, NY
- 2,311
05-27-2008, 09:08 AM #15
I like electro freeze
05-27-2008, 11:02 AM #16
- May 2008
- Lower Arkansas
- 27
Off the subject, but curiousity has me. Have any of you run into the machine that blows air (or some gas) into the almost frozen milk product at the time it is drawn? That stuff is NASTY!!! Gotta lotta nerve to call it soft serve!
05-27-2008, 11:15 AM #17
- Jan 2005
- 2,311
05-30-2008, 04:51 PM #18
New Guest
- May 2008
- 2
Carvel just switched from Taylor to Electro Freeze. Sonic Drive ins, Old Country Buffets, among the larger chains with Electro Freeze.
05-30-2008, 04:57 PM #19
New Guest
- May 2008
- 2
Having been in soft serve equipment for 24 years, I would strongly recommend visiting stands in your area, tasting products. The machine really does make a big difference. Also check the reputation of the Distributor you will be purchasing from. You will, whether you want to or not, have a relationship with that company. Good Luck.
05-30-2008, 04:58 PM #20
- Jan 2005
- 2,311
Been awhile for me. I left just after TC died. Misrable old goat.
RAM Teaching Tomorrows Technicians Today.
05-31-2008, 08:28 PM #21
Professional Member*
- Jan 2007
- Frozen in UpState NY
- 56
The fact that Taylor uses a flooded chamber/evap system and the refrigerant is held back by nothing more then a rubber gasket.
Gasket goes bad and the machines gonna need a new "shell-hopper" system.$$$$$
You'll find the leak along the front wall inside the machine right in front of the expantion valves.
I sent maybe 30 machines to the scrap yard last season because of this.
06-01-2008, 10:12 PM #22
06-11-2008, 01:06 PM #23
- May 2008
- 4
hello everyone 1st post...the shell problem how much is it to fix? i bought a couple used 754's and i just notice its a little rusted in the front shell..
thanks
06-11-2008, 04:03 PM #24
- May 2008
- Lower Arkansas
- 27
Last evaporator set I bought for 754 was around $750 and took 7 hours to replace! Waaaa too much work for me!
07-19-2008, 02:32 PM #25
New Guest
- Jul 2008
- 3
electro freeze alot better than the taylor.i work on just about all the soft serves out there and electro freeze is about the best out there
07-19-2008, 10:47 PM #26I fully support the military and the War on Terrorism.
