Results 1 to 13 of 45
Thread: Testo 523 leaking
05-08-2008, 08:42 PM #1
Testo 523 leaking
Just got these about 2 weeks ago, first time I ran liquid refrigerant (410a) threw the low side it started pouring out, Ive only used them a handful of times
not happy
05-08-2008, 09:24 PM #2
Where did you get those from?
That is one of the recalled ones that leak.
You need to send it back and get the ones that have a small bracket on the bottom."Correct Installation is the Key"
.1 has killed more HX then Rush Limbaugh
What is your TESP?
05-08-2008, 09:27 PM #3
Check out the little grey plastic part on the bottom of mine, thats what yours is missing.
What is your TESP?
05-08-2008, 09:28 PM #4
Recalls had the code 701 to 706, at least I read that here, these are 803
They just got these in stock at a local supply house and I bought them the day they went on the shelf.
Ill definitely be sending them back either way
05-08-2008, 11:14 PM #5
- Jan 2005
- Akron
- 779
Swampfox,
That is definitely a recalled set. The recall was from last summer, but we had a small number of units that were not returned. I am afraid that you have one. There was a plug that failed internally. Please return them to testo for an exchange. Please drop me a PM via my contact info in my profile and I will see that a new set is promptly delivered and you receive a prepaid return box for the recalled unit. We will handle the exchange directly to expedite the process.
Sorry for the inconvenience.
Jim Bergmann
HVAC/R Technical Specialist
Testo INC.
or Contact Testo directly 1-800-227-0729JLB- Co Owner TruTech Tools Inc.
05-08-2008, 11:37 PM #6Karst means cave. So, I search for caves.
05-08-2008, 11:38 PM #7
I am a little sad seeing weber flaunt his gauges at me, while mine are sitting in jersey waiting to be returned. It felt wrong taking my brutes out today, where is my clean digital display.
Send my gauges back to me.
05-08-2008, 11:41 PM #8
Professional Member*
- Nov 2001
- east kansas
- 7,969
05-09-2008, 12:15 AM #9
Thanks a lot Jim, you have mail
05-09-2008, 08:33 AM #10
- Nov 2002
- Pittsburgh, PA
- 63
05-09-2008, 08:55 AM #11
Twilli says speaking of Testo Twilli called them today and spoke with "jordan" about his weak wand on Twilli's testo 318v and was told there was nothing that could be done about it due to the design.
No Heat No Cool You need Action Fast
05-09-2008, 09:07 AM #12
Sorry to hear about your "weak wand"
05-09-2008, 09:20 AM #13
