Results 1 to 11 of 11
Thread: 1 ton condensor
    Colorado flatland native
    1 ton condensor
    does anybody make a 1 ton condensor and fan coil? I have a tri level with a 10,000 btu load, and I dont want to install a 18,000
    Walter Matthau
    newton,mass.
    I have the same problem, I ended up ordering an 18,000...I could not use ductless splits due to walls that were full of stuff already... Yesterday they told me they wanted the condenser on the other side of the building...so instead of 20' I have to go approx. 120'...oh well...
    "Nothing else can poison our culture, corrupt our society or ruin the character of our people like unearned money or unearned opportunity." -- James R. Cook
    "Fooling around with alternating current is just a waste of time. Nobody will use it, ever." Thomas Edison, 1889.
    Guess I'll just dump some in a hall.
    Walter Matthau
    I don't know
    Just got off the phone with york. Wish they made a 1 ton coil and tiny air handler to match.......
    Walter Matthau
    Quote Originally Posted by spotts View Post
    Run the 1.5 ton AH on low speed with the 1 ton CU. You'll be all set.
    Feb 2005
    Barrie, Ontario
    I've seen this plenty of times. Usually changed out the FC's orifice with the CU's orifice, if they came with one.
    Nowadays, if your FC comes with a TX, it will probably hunt a bit.
    As well, I've checked about ductless splits before and couldn't get a "outdoor section only" without buying the entire ductless. Gutting the OEM electrics from the outdoor isn't a big deal.
    Is this a Fabreze moment? C.Y.D. I'm voting white elephant. 2¢.
    Here and there
    Ducted Fujitsu Jack ?
    gotta make sure their are 1 ton models Call in the morning if you wish
    The Yorkie 1 ton with 1.5 ton air handler slowed down will work perfectly. I did it for a friend's bonus room.
    Yea, but Amana's 1.5 ton AH is smaller. If the york made a 14" AH to match their 14" Horiz. coil they'd really have sumpthin.
    Walter Matthau
    I've used the York with a 1 ton Unico that was pretty sharp!
    Walter Matthau
