    Jun 2007
    Out of this Hemisphere
    NAE55-Access the SCT System "Offline mode" to make changes to database
    can someone please tell me how to access the SCT System "Offline mode" to make changes to database
    Thanks, Chet
    Nov 2005
    Do you have SCT loaded on your machine? It should be in your program list if it's loaded.
    Jun 2007
    yes, I have SCT loaded
    Nov 2005
    Quote Originally Posted by Chet1508 View Post
    So what's the problem? I need more information.....
    Can you open SCT?
    Do you have an archive database to open? Or is SCT just a blank page?
    You must have an archive (backup) copy of your database in SCT to make changes and download those changes. If you don't have a database to work with, you will need to build one with the correct site/nae names and upload. After you have uploaded the online database, you can make offline changes then download the changes. It's not as hard as it sounds....
    NW Ohio
    Thanks, Chet
    You can access it remotely, assuming SCT is on your ADS, by using the same shortcut you use for the UI and changing metasys to sct. ie 'https://10.18.1.6/metasys' for ADS UI, 'http://10.18.1.6/sct' for SCT.
    Jun 2007
    Thanks guy's I am all set, I didn't realize how easy it was too use
