Results 1 to 13 of 22
    May 2008
    Need AC help in Fort Myers, FL
    I need freon added to my AC unit in Fort Myers anyone that can help out there.
    Aug 2001
    forney texas
    how do you know you need freon?
    May 2008
    I have a leak in my airhandler
    Houston,Tx.
    Quote Originally Posted by mjrobs View Post
    Needing freon is no reason to let the baby go down with the bath water no big deal, everyday in Houston someone needs freon, now if you needed 15 lbs you might start saving for a new Air Handler.
    Houston,Tx.
    O God no, I think I see a white horse coming down through the clouds,
    and a rider holding a double edged sword.
    I'll come down and put it in for free.
    Just pay me a $1.95 per mile trip charge.
    May 2008
    Can the leak be fixed in the air handler or do I have to replace it?
    Someone would have to look at it to know if the leak can be fixed or not.
    Some can, others aren't worthwhile trying.
    How old is the unit? Most evap. coil leaks can't reliably be repaired. Repair one leak , a month later , another , next month , another . You get the picture. It's in your favor to bite the bullet, and install a new unit.
    May 2008
    Depending on the age and condition of the air handler - If unit is under 5 years old the part should be under warranty from the manufacturer, and you would probably just have to pay for the installation of the part. If the unit is over 5 years old you need someone to look at the overall condition of the air handler and determine if it is worth paying for a new coil + installation. In SW Florida the avaerage life of an air handler is around 8-10 years, due the the harsh conditions our systems have to deal with. We have 2880 cooling hours ( highest in the country) and extreme humidity. These conditions really take a toll on our systems. Either way unless it is a minor leak,that is easily accessable it is usually not practical to try a repair.
    SW FL
    Smile Ft Myers firms
    .... AC unit in Fort Myers.
    Can anyone help out there?
    Sure, several hundred firms can.
    J & D A/C 5651 Halifax Ave Fort Myers, FL 33912
    (239) 415-4271‎
    http://www.conditionedair.com/ 939-1177
    Haines A/C 992-1551
    Designer Dan
    May 2008
    I am looking for someone to do this as a side job!!!!!!!!!!
    Jul 2002
    Zelienople, Pa
    You just grew legs to this thread.
    It will be 15 pages long this time tomorrow!
