Results 1 to 2 of 2
    Apr 2008
    Anaheim,CA;Las Vegas,NV;St. Robert,MO
    ESUSA NexSys, Siemens & Carrier for sale
    Part # Desc. Qty.
    NexSys Items
    NXP-FSC-01 Flexible System Controller 4
    8UI 8 Universal Input board 17
    4D4A 4 Digital Output (relay),
    4 Analog Output combo board 7
    8DO 8 Digital Output (relay) board 4
    NXP-PWR-01 Power Assembly 2
    - misc. ribbon cables
    Apogee/System 600 Items
    545-719 Apogee Open Processor 4MB Mem. P2/P1 1
    540-100 Variable Volume Controller 4
    540-105 Heat Pump Controller - Single Stage 1
    540-103 Constant Volume Controller 1
    540-863J Static Pressure Controller 1
    540-110 Unit Cond. Controller 1
    544110 UC Processor Card - never used 3
    536774 Immersion Temp Sensor 100ohm Plat RTD 1
    544-578 Outside Air Temp Sensor 1
    544760A Room Sensor - RTD Beige 2
    544760B Room Sensor - RTD White 1
    540-670A Room Sensor - Thermister,Setpoint,OR Beige 1
    540660A Room Sensor - Thermister Beige 1
    544772FB Room Sensor - RTD,Display,Override White 1
    SQS82 VMP42 Series Valve Actuator 1
    Powers System 600 4 Output Relay Board 1
    PTS4.1G Floating Point to Pheumatic
    w/Power Brown-Out Reset 3
    PTM6.2N100K 2 AI 100k Thermister Input Module 7
    PTM6.2Y10S 2 AO 0-10vdc Output Module 4
    PTM6.2I420 2AI 4-20ma Input Module 3
    PTM6.2Y10S-M 2 AO 01-0vdc w/HOA Output Module 5
    PTM6.2U10 2AI 0-10vdc Input Module 1
    PTM6.2Y420 2 AO 4-10ma Output Module 1
    PTM6.2C 2 DI Pulse Counter Input Module 1
    PTM6.2D250 2 DI Dry Contact Input Module 1
    PTM6.2Q250-M 2 DO w/HOA Output Module 2
    PTX6.L Low Volt Terminal Block 6
    PTX6.H Hi Volt Terminal Block 2
    537-789 Laboratory AO-P Module 1
    Carrier VVT Items
    MST-01E Temp System Thermostat w/Time Clock -
    Factory Rebuilt 1
    MST-01ES Temp System T-Stat wo/Time Clock - new 2
    TSR-01 Temp System Relay Pack - new 3
    Misc.
    RP SIGA-IS Intelligent Detector - Edwards Systems 1
    TC-1103 Electric Room T-Stat - Barber-Colman 1
    NDCO-03-KIT Communications Card - ABB 1
    UIPCM Universal Input to Pulse Converter - Atkinson 2
    3-PSMON System Power Supply - maybe L&G System 600 or Johnson? 1
    Feb 2011
    would Like to buy a psmon power supply can you email me through my profile?
