Results 1 to 2 of 2
    Las Vegas
    Confused Lexicons handled differently in embedded jaces?
    I'm programming a job for the School District. They have some requirements for status colors, i.e. overriden = yellow.
    I programmed the job on a softjace I had available while I waited for the jace 6 to come in. I made a lexicon that gave the proper colors for overriden values. When I overrode the output on a bacnet device it showed up as yellow. No problem. When the jace 6 came in, I loaded the station and the lexicon on the jace 6, ensured that the profile had the proper lexicon as the language. Eerything works great, except when I override an output, it comes up as the default MAGENTA. WHAT THE HECK?
    I even tried making a new lexicon with the same values, and it still comes up as magenta no matter what I do.
    Why does this work in a soft jace and not in a Jace 6?
    Am I missing something? WTF is going on here? Anyone have any ideas?
    Las Vegas
    Thumbs up Solution Found
    For those of you who may be interested, I finally found the solution, and it appears that there actually may indeed be a difference.
    In the beginning when I created the lexicons in the softjace, I named them either "CCSD" or "ENGLISH". These worked fine in a softjace, but the Jace-6 wasn't digging the naming convention.
    I made another lexicon and simply named it "en" and loaded that into the Jace-6, and all is well.
    Lesson learned, hopefully anyone reading this will learn from my mistake.
