Results 27 to 39 of 40
Thread: Heat pump advice for the south
05-17-2008, 02:23 PM #27
Professional Member*
- May 2007
- DC Metro area
- 3,233
It sounds like you've chosen a good system and you're happy about it. Look forward to seeing some pics if you decide to take them.
05-25-2008, 03:18 PM #28
- May 2008
- Atlanta
- 22
Ok, here is some pictures of what has been completed. They were here Friday and Saturday and are still not finished, but thats what happens when you come at 9:30, go to lunch at 11:00 and leave at 3:30. Someone, or as the installers called him "someone who went to school" is comming out Tuesday to finish installing the dehumidifier and IAQ thermostat.
The guys did not really want to work because of Memorial day, but they were afraid of the master tech/boss so they did not dare not show up (don't people know voices carry through ductwork?). They were one of the messiest bunch like leaving drywall matter all over the washer/dryer, but that is typical here in GA. I am glad the laundry room is being redone.
Before:
After: Ignore the wiring; thats something i'm working on.
So here are some issue:
1. They did not bring a condensate pump or pvc with them and they were going to reuse the old pump. I said NO WAY so they went to Lowe's and picked up a Water Ace RCU20S and reused the old clear tubing from the old pump that I put in my trash can! That new pump is so noisy; it sound like a bearing grinding when it comes on and can be heard all the way upstairs. Is this normal sound for one of those pumps?
2. Every time the VS blower comes on or turns off it makes a "thump" or two sound. Also today when the VS blower turns it sound like that sound you hear from your car brakes when the metal clip on the pads are touching the rotors.
3. They used a lot of mastic, but there is still some leakage, but that should be easy to remedy. One location I am not sure about though is around the two breaker locations:
I can feel a lot of suction when I put my hand over them. Is this normal?
4. They were going to run the tubing across the ceiling again when I noticed it tied up. When I asked them about it they said they could not bend the tubing to get it above the ceiling. I had made it clear that they could cut the drywall so the tubing can go above it. So in the end they ran it above, but made more damage to the drywall than necessary and it was still not fully pushed into the wall vertically so that new drywall could be palced over it.
Now to whoever told me to go with the Ultra-Aire needs to be slapped over their with it, but first I need to find 10 very strong people who can pick it up first
This thing is a monster!! The pictures of it on their website are not to scale. They should put a warning that "object is much bigger than it appears".
This is where it will have to hang:
Here is where they made the fresh air hole:
On a lighter note, the Aeroseal duct sealing work was great! They reduce leakage by 65%. They caulked all the return and supply ducts where they meat the wall and floor, placed HVAC tape or metal over any large problem spots, then used that white stuff to seal the ducts internally. I also replaced some of the ducts in the garage. The major problem areas were the 90° elbows and I replaced 5 of them and taped up 2.
05-25-2008, 03:25 PM #29
- May 2008
- Atlanta
- 22
2nd Post with more pictures
Here are some other pictures of the install:
05-25-2008, 03:36 PM #30
- Feb 2007
- Las Vegas,NV
- 719
Thats one of the crappiest installs I think I've seen on here yet. Looks like you've got some real winners doing that one, I hope the thing ends up working out o.k. for you. I would be very upset if someone did that kind of work in my house! How many buckets of mastic did they use?
05-25-2008, 11:01 PM #31
- Feb 2007
- Las Vegas,NV
- 719
I'm really surprised no one else has added their criticism to these pics. Usually when somone posts some raunchy install photos the whole place goes nuts!
05-25-2008, 11:11 PM #32
- May 2007
- DC Metro area
- 3,233
Maybe they're speechless.
It's easy to sit back here and criticize optomos's installation, but we have to put ourselves in his position as well. He picked a proposal that he and many others (myself included) thought was a good system installation by a competent company. From his description of the process and images, I would say that the installation looks rather sloppy. Optomos, I suggest getting in contact with the sales person you talked with and asking him to come review the work done (and maybe even a manager, too). Ask him (them) if this is what they consider quality work--mastic spewed all over the place, sloppy lineset, etc... The installation certainly isn't the best I've seen, but I was unimpressed when I first saw the pictures and think some improvements can be made. Good luck.
05-27-2008, 07:04 PM #33
- May 2008
- Atlanta
- 22
The owner and sales person are coming out tomorrow plus the person that is suppose to finish wiring the ultra-aire and Honeywell IAQ. He had problems on Monday getting the IAQ to work with the dehumidifier. One of the guys had set up the Ultra-Aire to pull from the return and send back to the return so that the dehumidified air goes over the coil and set the blower to run at a low speed. I was like umm, why? Doesn't that defeat the whole purpose of the whole house dehumidifier? So I hope some of this will be resolved with the owner tomorrow.
Other than that, the VS blower is great after they adjusted the turbine because it was rubbing against the housing. The CFM it puts out is unbelievable and so is the suction. The rooms where there was very little air flow or inconsistent temperature is now consistent with the rest of the house. The garage is warmer then it was before, when the leaky ducts were keeping it cooler then upstairs
The outside unit is also very quite.
The owner said that he will make sure I am very satisfied with the job; I certainly hope so.
If any of you see something wrong please let me know so I can point it out to the owner.
Here are some more pictures of the Ultra-Aire installed:
05-27-2008, 07:35 PM #34
- Feb 2007
- Las Vegas,NV
- 719
Everything I have seen looks wrong, the ductwork is sloppy, the air handler install is sloppy, the mastic looks like you handed my three year old a paint brush and said here have at it! The fact that they left the mess all over the washer and dryer, plus the fact they were going to reuse the old condensate pump, and whatever else, jsut proves that are a bunch of hacks. I wouldnt let anyone install that mess in my house even if it was free. Sorry to be so harsh, but this industry shouldnt have people doing work like this!
05-28-2008, 09:31 PM #35
- May 2008
- Atlanta
- 22
The owner and the senior tech came out today. They replaced the noisy Condensate pump with a Diversitech CP-22, put in a new hose running from it, put in the p-trap, sealed some more around the airhandler, finished connecting the Ultra-Aire to the IAQ, reran the wiring so that it looks cleaner, and some other misc things. In 2 weeks they will come back once the mastic is fully dried and paint it so that it matches the airhandler.
I have it set at 74 with RH@40-45%. I can't believe how crisp and easy the air is to breath and at 74 I am freezing my tushh off! Even though that Ultra-Aire dehumidifier is a MONSTER, I do have to thank whoever recommended it to me
Thank you all who have contributed. I will post some more picks when the laundry room drywall is repaired and painted. It will look much better then.
05-28-2008, 09:44 PM #36
Wait till its 72* outside, and 72% RH outside, and you don't have to set your stat to 70, you'll thank him again.
05-29-2008, 10:24 AM #37
Like others have stated, the installation is not totally to my liking. I like your discription about the crisp feeling you are discribing. I am glad I held off on countering the comments about the looks of one of my children- Ultra-Aire xt150h. It is like marrying the plain woman who has no equal. After the 1st week, preformance is everything.
Set the t-stat up to max that you are comfortable. Warmer temperature decreases the a/c and dehumidification energy and increases the life of the equipment. Another energy saving opportunity is using the t-stats to set-up the temperature when the home is not occupied for extended times. We typically expect to be able to maintain <50%RH. Do not change the dehu set point while setting the temperature up. This is like a shakedown cruise. Are you operating fans continuously? What about fresh air? Keep us posted on likes/dislikes. Thanks again for trying a monster product. We do have small units but not better. Regards TBBear Rules: Keep our home <50% RH summer, controls mites/mold and very comfortable.
05-30-2008, 02:21 AM #38
- Nov 2004
- SW FL
- 5,355
Relatively speaking ...
Designer Dan
It's Not Rocket Science, But It is SCIENCE with "Some Art".
05-30-2008, 02:40 AM #39
- Nov 2004
- SW FL
- 5,355
N I C E
Many Southerners actually have to wear sweaters when it is 74'F at 40% R.H.
Trial setting: 78' to 80'F at 44%
Of perhaps, as many prefer a couple degrees less for sleeping.
Do you wish to breathe even easier, try a portable filter unit
good for up to 450 sq feet
Models 525, 546, 547 ...
.. maybe available at Lowe's or similar store
http://www.hunterfan.com/pages/cat_a...php?roomSize=1Designer Dan
