Thank you for choosing us to replace the heat pump system for your home. We will furnish and install:
1. Amana #ASZ16048 four ton heat pump and #CAPF4860 coil and #MBE2000 variable speed air handler with 15 kw electric heater (system efficiency 16.0; 9.75 HSPF). This uses the environmentally friendly R410A refrigerant.
2. Remove and haul away existing equipment. Set new equipment in place and reconnect ductwork, electrical, control wiring, and condensate drain piping. New refrigerant piping will be installed. The air handler will be set in an emergency drain pan with safety float switch.
3. We will also install a Honeywell YTH9421C1002 Vision Pro IAQ thermostat.
This includes the TH9421C1004 thermostat and the THM5421C1008 equipment interface module.
4. Option (1) Aprilaire 2200 Media Air Cleaner.
5. Option (2) Ultra-Aire XT150H central dehumidifier. We will also install a 6” outside air intake with a manual shut off damper.
Amana provides a TEN YEAR PARTS & LABOR warranty. We guarantee all workmanship and material for one year.
Please call with any questions or to schedule the work.
