Results 1 to 8 of 8
Thread: System Options
05-01-2008, 05:34 PM #1
- Jun 2004
- Milwaukee, WI
- 256
System Options
Out of curiosity do any of the other systems out there offer pre programmed systems of the sort that Trane offer's. Such As Chiller Plant Manager, VAS, Area control, Night Economizer, Static Pressure Optimization, ASHRAE Ventilation Reset.
I know that 3 years ago JCI, TAC and Honeywell did not and was curious if there was anyone else.
I have noticed through the years that as you look at a standard building programming setup there is not a nice turnkey program for setting up RTU/AHU VAV like VAS does. The options that Trane puts together for these systems I think make jobs consistent and efficient.
Please dont make it a bash fest on all manufactures, I just like to know what the others do to increase the efficiency and make these systems come together.
05-01-2008, 06:28 PM #2
I work almost exclusively with Trane equipment and I have no clue what you are talking about. Are these 'systems' all inherent to Summit? Are they available through equipment sales or only controls sales? My guess is it is strictly controls which means it's locked up tighter than a crab's a** around here.
05-01-2008, 06:39 PM #3
Banned
- Mar 2006
- 3,641
It is done by actually programming the system. Does it always get done? No!
Should it? yes.
Trane has some cool and easy turnkey strategy's if your building is top to bottom trane everywhere/everything.
That being said , I have seen a plenty of bastardized summit buildings as well.
So as ussual, it boils down to the Techs and the engineering put into it.
05-01-2008, 07:14 PM #4
05-01-2008, 08:35 PM #5"How it can be considered "Open" is beyond me. Calling it "voyeur-ed" would be more accurate." pka LeroyMac, SkyIsBlue, fka Freddy-B, Mongo, IndyBlue
http://threedevilskennel.com/ - not my website.
Versatile Hunting Dog Federation - www.vhdf.org/
05-01-2008, 08:51 PM #6
05-02-2008, 01:16 AM #7
Carrier has been doing preprogrammed VAV control like you stated at least since early 90's, the older TSM/TCU had it. Carrier calls it linkage versus VAS. The VAV's are preprogrammed to work with Carrier units with PIC's. They will do Night Time Free Cooling, Static Pressure Reset, ASHRAE Ventilation, Optimal Start/Stop, etc.
They have also had a Chiller Plant Manager for at least 10yrs. They call it a Chiller Supervisor Module is capable of 8 chillers with Load Balancing, Setpoint Reset, Stand-By, Load Shed, Capacity Control, etc.
I worked on both Trane & Carrier systems and like both, each has plus & minus to the other. On a VAV system, both will yeild the same operation. It is easier and quicker for me to setup a turnkey operation on Carrier than it is with Trane. Trane use a BCU to hold all the programming, which you need to setup and define. Carrier already has everything programmed in the devices and all you need to do is enable the functions and define parameters.
Originally Posted by Qui-Gon Jinn (Star Wars Episode 1)
05-02-2008, 03:59 PM #8
- Jun 2004
- Milwaukee, WI
- 256
Hey thanks for the input on the Carrier system. That is one system I have not worked with much so it is good to know. I have just heard that York and JCI has come out with a new VAV application with color touchscreen and MSTP Bacnet has anyone used that yet?
I am not using this as a sales pitch I was trying to learn what other manufactures offer systems to standardize everyday operations of HVAC systems.
