Results 1 to 13 of 45
04-30-2008, 08:12 PM #1
Digital Psychrometer --- Thoughts
Well with warmer weather coming back I went to pull out my Sling Psychrometer for doing A/C checks. And lo and behold it was no longer in my toolbox that I put it in when winter came. Best guess is one of the helpers I get pulled it out when getting something out and it either got left on a jobsite or "accidently" thrown out with trash.
So now I'm looking at getting a digital one, personally I'm leaning towards the Fluke 971. But looking for opinions from people who own these and some of the others.When you do a job, Always make it easier for the next guy, because you may be the next guy working on it.
04-30-2008, 08:25 PM #2
- Aug 2002
- Louisville
- 283
Testo H-2 Humidity stick. You can stick it way into the air stream,
04-30-2008, 08:43 PM #3
- Jan 2005
- Akron
- 779
The Testo 605 h-2 is a rock solid instrument, WB, DB and RH. Very long battery life, easy to read display, designed to go into the duct, and simple to operate. Very high repeatability of the measurement parameter. full specs are at trutechtools.com
JLB- Co Owner TruTech Tools Inc.
04-30-2008, 08:44 PM #4
- Apr 2007
- 6,286
Check out my profile.......606-2 rocks....dewpoint, wetbulb, RH, drybulb....it's also a moisture meter for wood and such. Very accurate and quick response.
04-30-2008, 08:46 PM #5
- Jul 2007
- Chicagoland
- 468
I use the testo 410-2 and like it alot,but my previous unit was a UEI so I might not have a good baseline.
05-04-2008, 08:25 AM #6
The only thing I see about the Testo is, any parts house I goto has to order it. But the 971, I can walk into 3 or 4 different parts houses and get one "off the shelf".
05-04-2008, 10:25 AM #7
- Jul 2007
- Chicagoland
- 468
I hear ya! Fluke and fieldpiece are easy to find, along with lesser brands. I only have 2 testo items the, 410-2 came as a freebie w/my 327-1 and I am impressed enough w/ the engineering to consider testo first as I browse for tools to buy in the future. I think with testo's new look and growing rep. it wont be long before they find their way onto the shelf in more places.
05-04-2008, 10:32 AM #8
I have the Amprobe THWD-3. I find I use it more often than I expected for checking ambient air temps. I am very pleased with it. I do wish it was a little faster reading. The spec is 10 seconds for reading but that seems like a long time when I'm working on something.
05-04-2008, 10:52 AM #9
- Sep 2005
- Texas
- 2,793
it always seems to be a crap shoot with digi's and we haven't even mentioned calibration issues
05-04-2008, 10:59 AM #10
- Aug 2002
- Louisville
- 283
Testo can be ordered online at www.trutechtools.com and response is faster than most supply houses I have dealt with in 25 years in this business. I had a strap break for my testo 523. I contacted Jim and had a replacement in 2 days. I have had locals that after we filled out the paperwork it left 2-3 days after I turned it in. 2 weeks I would finally get a call that the replacement had arrived. The owner of trutech has ver 40 yrs as an hvac tech so he knows what we do in this industry. Just my .02 cents
05-04-2008, 10:59 AM #11
- Apr 2007
- 6,286
Well I can at least say I know the Testo is accurate....used it in my profile pic to do a vac. test on water and when the glass surface temp got to the dew point temp that my 606-2 was reading moisture started forming...at worst .1º off.
05-04-2008, 11:27 AM #12
- Aug 2002
- Louisville
- 283
How's this for accuracy
05-04-2008, 04:43 PM #13
- Jan 2005
- Akron
- 779
Rick,
When you consider that the Wet-bulb a calculated measurement from temperature and humidity, you really start to appreciate the accuracy.
