Page 1 of 7 1234567 LastLast
Results 1 to 13 of 81
    Apr 2002
    Currently: Denver Colorado area, Previously: East Coast to West Coast + many cities in between.
    Question Mastercool Digital Manifold/Analyzer
    Who has tried the new Mastercool HVAC Digital manifold?
    What are your feelings about it after using it for X time?
    Is it worth the money?
    Will it last if you don't abuse it?
    Alex
    Veterans Home Yaphank, NY
    Smile
    Quote Originally Posted by alexw View Post
    Before spending on that, go with one of the proven. http://www.yellowjacket.com/HVACRPro...l=5&c=33&p=310 JMHO
    RAM Teaching Tomorrows Technicians Today.
    The company that makes the digital yellowjacket puts the same gauge out for about 100.00 less than yellowjacket. I'll do some research and find out who makes the gauges for yellowjacket. I saw it a while back, but can't remember.
    T
    Smile
    [QUOTE=Redsheanazar;1844483]The company that makes the digital yellowjacket puts the same gauge out for about 100.00 less than yellowjacket. I'll do some research and find out who makes the gauges for yellowjacket. I saw it a while back, but can't remember. That would be Doug Lockhardt a member here. http://www.digi-cool.com/
    Float'N Vally, MS
    Quote Originally Posted by Redsheanazar View Post
    T
    Digi-Cool. And they are coming out with a lesser expensive model.
    Of what I have seen, I would stay away from Master Cool. Money better spent is for DG, YJ or Testo. IMHO
    Life is too short, Behappy!
    TFMM
    T
    that co. would be digi cool, and they are making lsser (cheaper) gauges and better (more expensive) gauges than the YJ's. the YJ set is kinda middle of the road, and i have a set and love them. i am pretty sure that i wouldn't buy anything lesser than the YJ set that i currently have and just beware of the first generation testo's. they have had some trouble with the gauges sealing internally. but all that is gone with the second generation testo's
    Aug 2005
    Unfortunately your characterization of the less expensive Digi-Cools, which incidentally will be the DRSA 1600 as being "cheaper" is inaccurate. The only exclusions that will differentiate the 1600 from the 1200 are the elimination of the selectable 1 to 5 second/Hold option and the high and low pressure reading retention capabilities. Two features that alot of tech's and probably in particular entry level tech's would not utilize anyway. Aside from that the powerhead was left unrevised, it's pure Digi-Cool.
    The recall of the second generation 523-v.2 was to address potential refrigerant loss at the hose ports, I am not personally aware of any of the version 2.00 523's [first attached image] that were actually found to be leaking. The second generation 523 v.2.01[second attached image] added a protective skirt around the hose ports and is very easy to differentiate from version 2.00. A later revision to the second generation 523 in the form of a firmware flash, to address update rates resulted in the designation of a version 2.02 - if you're interested the result of that free flash upgrade can be seen in this clip: http://digitalzeus.wordpress.com/200...rmware-update/
    Float'N Vally, MS
    Quote Originally Posted by servicef1rst View Post
    100% agree!
    After usuing Digital gauges there is no going back. If a tech is going to stay in this field, I would save your money for a "good" set. It is money well spent.
    TFMM
    i don't mean to say the lesserexpensive ones are inaccurate at all!! i have the YJ set myself and they are awesome!!! i am looking into getting a second set for back-up use
    Jun 2005
    South Jersey
    I've never seen a Master Cool anything that was "worth the money"..........................jmho
    I have several mastercool tools and will have to agree that lately products do lack in quality and customer service has become nonexistent.personally have a set of analog gauges that leak on a regular basis if I don't keep the orings lubed.
    weber's Avatar
    weber is offline Professional Member/Membership Committee
    Southern Ca, Elkton Md
    Alex haven't you posted similar threads about this product?
    Don't you have a special interest in this product?
    "Correct Installation is the Key"
    .1 has killed more HX then Rush Limbaugh
    What is your TESP?
    weber's Avatar
    I think before it was the stargate something.......
    Are you just in the market for a set of digitals and cannot make up your mind?
    What is your TESP?
