Results 1 to 7 of 7
    Post how to calculate the dehumidifier size
    Dear Forums members
    I would appreciate if anyone advise me how to calculate the dehumidifier size to bring the RH from 90 % at 22 deg C to 50 % at 23 deg C size of room is 10 x 10 x 6 mtrs with chilled water fan coil unit ( no fresh air intake expect infiltration only)
    Regards
    Yash
    TB, may be along soon.
    What is stored in the room, how much infiltration. Just a few things that you should include.
    TQ, it has some aircraft hardware and i consider infiltration equal to one air change....
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by yashsodhi View Post
    One air change per hour? What is the wettest outside condition or region? How many occupants? Regards TB
    Will it have wash down stations inside, or other humidity generating devices/appliances inside.
    Apr 2002
    One air change in the Midwest
    http://www.heatpipe.com/ProductsServ...&#37;20450.pdf
    One air change in the Amazon Rain Forest
    http://www.heatpipe.com/ProductsServ...BKP%201000.pdf
    One air change in the Persian Gulf
    Use two of the Amazon model
    Apr 2002
    Outside air unit pressurizing the place with dry air would be the way to go. Don't even reheat the air, use it as first stage cooling
