Page 1 of 4 1234 LastLast
Results 1 to 13 of 51
    Wondering which HiEff furnace to buy
    Have quotes on Lennox G71P, Ruud Ultra 90, Bryant plus 90i & kenmore 76141, all are supose to be Hi eff, wondering which might be the best way to go & if some have more problems with them, I want which ever i chose to have a vs dc fan motor, or is there another one out there I need to look at
    Lancaster PA
    Check into a York Mod furnace, 95% AFUE, its available with a VS blower.
    Toledo, Ohio
    Rheem Mod, Twilli has it in his trailer
    No Heat No Cool You need Action Fast
    Most manufacturers have high efficiency furnaces and VS blowers. Find a real good installer. It's more important than brand. Although some around here have their preferences, the nameplate on the unit doesn't trip my trigger.
    Jan 2006
    Quote Originally Posted by AltaGraham View Post
    e-mail me,e-mail in profile
    The york line which includes luxaire and coleman have a 67 step modulating gas valve in the higher end unit, most of the others have a two or three step valve that I am aware of. The furnaces you listed as well as others will work well. You should be buying comfort not price if you are looking at this product. That means you need to find a good contractor in your area and work with him to determine what is best for you.
    Apr 2008
    Toronto, Canada
    take a look at the rheem modulating. thats what i am going with. i wish i had mine installed so i could tell you about it first hand. but after looking at many brands i decided on the rheem for these reasons:
    - spark ignition that is reputed to be very reliable (HSI needs to be replaced not and again and even more often if there is contaminants in the air)
    - modulation should increase comfort level - it just makes sense to me that a furnace should vary its output based on heat loss at a given time. after realizing thing the idea of an on-off single stage or double stage seemed less effective
    - stainless steel primary and secondary heat exchangers with lifetime limited warranty
    - 11 year pretty reliable track record, i am told on this forum
    - 10 year transferable parts and labour warranty
    Apr 2004
    Plexus, just so you know the factory HX warranty is for a new furnace, the others only give a heat exchanger.
    You'd be hard pressed to find a dissatisfied Rheem/Ruud Mod customer in that 11 years.
    Apr 2008
    Alberta Canada
    Carrier all the way
    I would go with Carrier Infinity 95%, the quiestest furnace money can buy. Where are you located. If you need more information go to my profile and email me.10 year parts and labour
    Do it right the first time.
    NW burbs of Detroit
    Westinghouse 2 stage 95% with vs blower.
    10 years parts warranty
    10 year replacement warranty on furnace if heat ex fails
    and a labor allowance to pay for installation.
    I still submit if the mods are so robust that everyone would be making one.
    So far all we got are Rheem and York. Both have had their own dogs in the past.
    Who remembers Triathlon and the the 90% drum ht ex?
    Lancaster PA
    Lennox now has a mod.
    Carrier has what the call a mod.
    NW burbs of Detroit
    Ok that make three and 1/2,
    Still hardly industry wide.
    Lancaster PA
    Give it time. The rest will follow.
    In the next 2 to 3 years, it will be harder to find a manufacturer, that doesn't have a mod, or some thing they claim is a mod.
    I think Trane is suppose to be coming out with a 3 stage.
