Results 1 to 7 of 7
    Apr 2008
    XL-50 status "stop"
    I have airhandler with xl-50 was working fine until the other day when I had steam valve actuator fail and went off on high supply temp. Changed actuator, cleared alarms, now I dont know how to restart application. Shows application stopped but mode is occupied so fans etc should run. Unit operates normally in manual modes for DO and AO points (fans,valves,etc). I have no prior experience with these controllers, any help appreciated.
    Jan 2002
    Fort Worth\Dallas, Texas
    Have you tried cycling power on the XL50?
    Go Rangers!
    Apr 2008
    Smile Thats all it took, I feel so stupid.
    Thanx lwarren, I cant beleive I didn't try that, god knows I tried everything else (except for the reset button which I knew would lose the program I dont even have a copy of). Thanx a Bunch
    Jan 2002
    No problem, glad it worked.
    I have a bunch of those at one particular site and everytime a storm comes through the application just stops and the customer has to go around and cycle power to them.
    Go Rangers!
    Jan 2006
    Sydney Australia
    you ought to flash the application to flash memory, especially if you don't have the project backup
    porch
    Quote Originally Posted by justafitter View Post
    What are you using to talk to the XL50 with. You may be able to make a basic backup.
    Apr 2008
    I only have the MMI.
    I don't have a laptop or software. I guess I could have customer go back on installing company to get software backup.
