Page 1 of 5 12345 LastLast
Results 1 to 13 of 54
    Apr 2008
    Houston, TX
    Question 16 SEER vs. 13 SEER in Houston
    I am in the process of replacing my residential HVAC.
    Existing Unit Data:
    • Houston, TX.
    • 1500 sq ft, single story; ceiling fans in each room.
    • Existing unit is 3.5 tons York H2RC042S06 A /C; 80 kbtu furnace; York database shows the unit is 12 SEER, but local tech said it was 10 SEER.
    • Existing unit is 10 years old.
    • Evaporating coil leaking.
    • Existing furnace gas control (winter) unreliable.
    • Plan to stay in this house for several years (single, retired).
    I have been quoted a couple of installations to replace everything: condenser, evaporator, furnace, etc. The contractor is suggesting:
    • 4.0 ton Lennox A/C; either 13 SEER or 16 SEER; for example XC16 Condenser unit.
    • 90 kbtu furnace; for example G60UHV furnace.
    The 16 SEER unit is considerably more expensive than the 13 SEER, but I am drawn to it because of the really hot summers we are having in Houston, and electric costs are going up a lot.
    So, my question here is whether it makes sense to go with a 16 SEER replacement unit in Houston vs. a 13 SEER unit?
    Thanks.
    Kathleen GA
    Rextex:
    1. Did the 3.5 ton unit cool the house adequately (except maybe on the hottest two or three days of the year)
    2. What is electrical rate there?
    3. What was your highest electrical bill last year?
    Houston,Tx.
    Quote Originally Posted by retexan599 View Post
    Thanks.
    I personally don't think in "Houston" you will benefit from a 16 seer system, we try and push 14 seer at most here, but as always us a/c companies have various opinions.
    Apr 2008
    Houston, TX
    Generally in the summer afternoons I strip down to skivvies and run the ceiling fans faster. It is quite possible that my refrigerant was low last summer.
    Approximately 14-16 cents/kwh.
    August 2007 my bill was $220. However, I kept the thermostat at 81 to minimize the electric bill.
    Thanks.
    4 tons for 1500 sq ft? WOW! That the norm for Houston?
    I think you need Al, Mr. Bill or Jason out there to do it right!
    May 2002
    Houston Texas
    Forget about last year how did it function in the past. You need to have a proper load calculation performed and have the supply and return ductwork assessed. Most homes in Houston have A/C systems that are too large but they function way below spec because of poor quality ductwork. If it can't breathe correctly it can't provide all that it should.
    You need to find a provider other than Reliant you can find a better rate. Look at Ignite or Dynowatt.
    Mr. Bill likes 14 SEER I sell more 16+ SEER than lower end. The higher SEER equipment will not save you a significant amount over 14-15 SEER equipment but will greatly increase comfort.
    Thanks.
    ok
    PA/DE area
    Trival Pursit Question: What is the most air conditioned city in the world?? Houston, Texas it was a question in the FIRST game they put out!!!
    It's NOT the BRAND,it's the company that installs it!!!!!
    May 2002
    Houston Texas
    There are older homes here that yes 4-tons would be correct. However a newer home with good windows and proper insulation can take a 2.5-ton unit.
    Dec 2006
    Dallas
    In theory, going from a 14 SEER to 16 SEER, you will consume about 13% lesss electricity for the same BTU's of cooling.
    Is it worth it? Plug in the numbers...and tell us how many months it will take to pay back:
    (Cost of 16 SEER - Cost of 14 SEER) / (Current Annual HVAC electric cost / 12) / 0.13
    If this wasn't so promising, then try this
    10 SEER to 16 SEER = 37.5% less electricity.
    Cost of new system / ((Current Annual HVAC electric cost / 12) + (Average Annual Repairs of old system / 12)) / 0.375
    Existing Unit Data:
    • Houston, TX.
    Thanks.
    Retexan599, if you would like a thorough evaluation of your whole system and what you need, just click on my name, 5 star, then click on view public profile and you will find my email and can email your contact information so we can contact you.
    Kathleen GA
    If this were my house I would:
    1. Caulk windows
    2. Add insulation to ceiling
    3. Add radiant barrier to ceiling where ever it is easy
    4. Invest in 15 or 16 Seer 2 stage AC unit
    After I did the above I would have a load calc done. You might could use a 3 or 3.5 ton unit. Oversizing cools faster but leaves humidity higher leaving you less comfortable. A two speed uses less electricity and removes more humidity.
    Gonekuku's math is corrrect - but the theory is inadequate as the SEER ratings do not take into account the inefficiency during startup. It takes 1-5 minutes for an HVAC to reach rated efficiency. Thus a 4 ton unit runing 10 minutes uses more electricity than a 3.5 ton unit running 11 or 12 minutes.
    If electricity goes up then higher SEER becomes more valuable. A two stage unit will provide more comfort and lower you electricity costs and help minimize the oversizing if you go with a 4 ton unit.
    SEER allows for cycling.
    EER doesn't.
    Houston, Texas
    That sounds normal if it's a BARN.
    A load calc is needed, it would normally be around 3 tons. The high seer isn't the most important thing here. You can crunch kw numbers until your fingers hurt, if it isn't setup properly inside, the 16 seer unit will take 20 years to pay for the upgrade. (that would be it's expected life plus 5 years.)
    Why is it the condenser the main topic of discussion. Sure this is what the homeowner sees most, and it comsumes more electricity than most things in a home. If it isn't connected to a system that will perform, it is like a race car with no tires.
    Maybe "attic rats" are a dying breed.
    Just try to communicate with the subs about the attic work, then connect your 19i?...lol
