    NY
    ec-67 SNVT_HVAC_Overid
    I need to code an nvo of snvt_hvac_overid. Does anyone know the math to do this. What I want to do is send an output of HVO_Maximum to vav boxes. based on an HEAT_MAX application mode from the ahu. I think I can do this with a type translator but it seems it might be easier in the EC-67.
    Any suggestion would be appreciated.
    New England
    I think you're SOL. You can't configure a freeprog nvo as SNVT_hvac_overid - it's not one of the available selections. You can do SNVT_hvac_emerg, but that will open the dampers, not set them at max flow.
    NY
    ctrlguy, that was my first thought because this SNVT was not an option in the 'Network Var Outputs' ->type selection but then I added a function block in LonMaker and an nvo. There I changed the snvt to hvac_overid and it show up that way now in the Network Var Outputs list. If I use 0,0,0 in the EC-67 I get HVO_Off, 0, 0 monitored at the fb output. I tried 7,0,0 but that didn't work. If I use 17, 0, 0 the result looks like HVO_Maximum, 10.54, 0 but the input at the VAV conrtoller still reads HVO_Off,0,0. I suspect that you are correct but was hoping for a solution. It looks so close.
    I have used this before to send a 'full' switch snvt. Looking at the format now I wonderif I might be able to make it work.
    *NETWORK VARIABLE OUTPUT WITH A SNVT_SWITCH*****
    The percentage and status is sent with the same variable in the SNVT_switch format
    SNVT_switch, resolution = 0,5%, lengh = 2 bytes
    1. 1st byte = 0-100% value
    Value is multiplied by 2 to match the resolution and by 256 to go in the 1st byte
    2. 2nd byte = On/Off value
    COMPRESSOR_ENA = ALM_PCT * 2 * 256 + ALM_STATE
    New England
    Interesting. Lonwatcher would not let me change the type to hvac_overid (nor did the plug-in). You might try creating an NVL in your iLON, default it to HVO_maximum and bind it to a freeprog nvi and see what the value is in the plug-in.
    NY
    I tried that now and it does not work. Everything looks ok but the value recieved by the ec-67 is all wrong.
    Feb 2005
    I believe you are trying to manipulate a 5 byte SNVT, and ec-67 can only handle 2 byte nvs, so as far as I know you are sol.
