Results 1 to 8 of 8
04-22-2008, 04:19 PM #1
19XR Cracked Oil Line/Heater Problem
I've got a new customer who has a m300 ton under-warranty 19XR that has had an oil line repaired twice. The second time, a bracket/clamp was added. There's oil in the same area again and the chiller would not start because of low oil temp (71*). The oil heater is room temp. I did not touch it as I'm n ot playing the voided warranty game.
Is this a common problem with these machines?
I already read the thread about having to pull the compressor or forcing the heater out/in to replace it.
jogas
04-22-2008, 05:21 PM #2
- Feb 2007
- Baltimore MD ( Balimer, Murilyn)
- 134
The clamp was a factory fix that was supposed to be added to all the chillers with the appropriate serial numbers.
As far as oil heater problems, the post you read earlier was the first problem I had heard of.
04-22-2008, 05:26 PM #3
Never heard of the oil heater problem before and over the last year i think we installed about 8 xrs and i have never had an oil heater issue.
04-22-2008, 06:11 PM #4
04-22-2008, 07:27 PM #5
not familiar w/ oil lines cracking. the shop i labor for has installed a number of 19xr/xrv. just to ask, what line & where? didn't see a bulletin.
04-22-2008, 08:20 PM #6
- Mar 2004
- Windsor ON Canada
- 390
If the oil heater is bad a new can be installed without compressor dissassembly. Remove the oil and the oil pump-filter assembly. The existing heater may need to be bent up to remove but the replacement goes in thru the opening with no issues. Our heater was actually rubbing on the casting where the oil pressure relief valve was situated causing it to rug thru the element. Have not had any issues with cracked oil lines.
04-25-2008, 04:55 PM #7
- Feb 2007
- 134
Sorry for the delay.. Did not receive a service bulletin. The stupervisor more or less said," here, put these clamps on the machines on this list." There might be a bulletin or some literature but as usual it's a state secret I'm not privy to.
You could try hvacpartners.com .
The oil line in question supported the new style oil filter on the smaller frame sizes. I believe the line feeding the oil filter was cracking due to vibration, but it's purely conjecture on my part.
04-25-2008, 05:33 PM #8
